Offroad & 4x4
altenator relocation?
Old Feb 4, 2004 | 01:22 PM
montster's Avatar
montster
Im posting this here as well as the I-6 section because Im sure Im not the first to want to do this and would like to know how it has been done and how it worked.
quick question re: smog pump
if I take it right out what do i do with the hoses? I would like to take it out and move the altenator up to that bracket. (I like water alt doesnt) that would put it almost a foot higher and farther from the flood
any help would be great
thanks
montster
__________________
83 bronco I-6 300
Old Feb 11, 2004 | 10:12 AM
fishmanndotcom's Avatar
fishmanndotcom
you gotta plug everythign up but you can remove qute a bit from there! i dunno if the alt will fit where the smog pump was!
-jason-
Old Feb 11, 2004 | 10:32 AM
ivanribic's Avatar
ivanribic
Check your measurements on the alternator. Some of them use a 7" (between mounting holes) and some us 9" large case alternators. If you build your own brackets there's no reason why you shouldn't be able to make it work although you might be best to go to a small case alternator if you don't already have one.
Btw, that truck looks like fun!
Old Feb 12, 2004 | 05:26 PM
hoxiii's Avatar
hoxiii
I had a '67 with an '81 300-6 in it and the alternator was mounted to the motor at the same level as the smog pump on my '85. Either the bracket can move straight up or the earlier brackets mount higher, it's one of those but i'm not sure. also like was said, if you're making your own brackets you can put it where ever you want.
Justin
