My 85 F150 loads of problems... Knocking, hard shifting
I have an 85 F150 with a 302 and an AOD, here is where the problems start :
1) Slight Knock in probably the front two cylinders, it started knocking shortly after replacing (horribly leaking) valve cover gaskets, I am guessing that some of the "stuff" on the inside of the valve covers got inside the engine and have made thier way to the bottom of the oil pan and clogged my sump causing oil not to be pumped correctly? any ideas?
2) Very Very Hard downshifting from 3rd to 2nd and hard upshifting from 3rd to overdrive have no clue why any ideas?
3) how hard is it to convert from 2wd to 4wd? and about how much can I expect to spend on the conversion or even converting from AOD to manual tranny?
I love this truck but sometimes it makes me wonder if I should have bought an ol' chebby for $500 less? any help here is much appreciated and I will keep you 85 f150 owners up to date on what happens so if it happens to you, you can find a problem
I agreed with f100guy.. how low do you consider low? 5,10,15psi? usually, when your oil pressure keeps dropping after your truck is fully warmed up, that means your clearances are too big (ie lack of good pressure for a while mains going bad). You could pull the motor and replace the mains and oil pump, but there are probably other problems now (cam bearing / wrist pins getting fried etc).
So, the inevitable has happened. time for a rebuild or a swap
btw, how many miles do u have on it?
umm well I got it at I believe 196,000 could be 296 though?! the title says 196 but you know how that is.... anyway I have a buddy that wants to give me an engine and a C6 tranny (both recently rebuilt for $400 and I am in need of cash so I'm thinking that would be the best bet at this point?! thanks for all the help though I really appreciate it!
Ok,,, not sure if this applies to your engine.... but does to my 86 302 ..... the factory put out a tech bulletin on knocking which says the first four main bearings may need either the lower main bearing replaced or both of them.. depending on the clearance... the 5 th does not need to be checked according to them.. check with a Ford dealer close by or something like Alldata.com and plug in your specs...
