1978 - 1996 Big Bronco
Drifting problems
Old Jan 28, 2004 | 12:11 PM
78owner's Avatar
78owner
Drifting problems
Ok I am buying a 78 bronco and it has a swaying problem it drifts. I had a 79 that had this same problem and replaced the track bar this solved the problem or at least I think it was the track bar I replaced. The original owner says he ahe hadt the bearing and new lock out tire rod end and gearbox all replaced within the last year.
any suggestion you can give will help
Old Jan 28, 2004 | 05:11 PM
blrman1962's Avatar
blrman1962
ball joints are a good sign of a drifting problem jack up the front and grab the tire at 12:00 and 6:00 position and see if it moves if you have play there its ball joints if you move the tire at 3 and 9 oclock position its wheel bearings out of adjustment or needing replacement. the only thing left is the drag link. a good front end shop can tell you what is up also. Thanks peter
Old Jan 29, 2004 | 08:23 AM
78owner's Avatar
78owner
I will give that a try I really appreciate the advice
