what kind (and grade) of Differential fluid should I use?
What brand would be the best, and what grade? Its an 03 XP EB 5.4 4x4
I am planning to change the transmission fluid this weekend and also the transfer case fluid, I know the Tranny should be replaced with Mercon V and the transfer case should be replaced with Mercon. But I was wondering about the Differential since the truck already hit 40K without any of these services.
Also, I have been reading about friction modifiers for the anti-slip differential. how do I know if my truck has the anti slip feature?
Thank you.
Gerardo.
Thank you.
Gerardo.
Use the recommended grade from the owner's manual and use synthetic from mobil or another good brand. There's a place on the tag at driver's door frame that'll give a number or letter code like H6 which is limited-slip. Also there's a tag underneath on your differential housing whick gives your gear info.
Seems to me the differential tag has a L on it for limited slip. Mine says 3L55 and I always thought it meant 3.55 ratio with the L replacing the decimal point to indicate limited slip.
Or you can jack up the rear wheels and turn 1 (in neutral) the other will turn the same direction if it's a limited slip.
Hope this helps
Hope this helps
juvat97
09-07-2011 10:59 PM
TimH
06-16-2003 08:07 PM
yosemite
1978 - 1996 Big Bronco
10-29-2002 01:19 AM
2000, 2002, 4x4, defferential, differential, expedition, fluid, ford, friends, grade, kind, meet, oil, type, wondering
