1995 Ford Van overheating but blowing cold air!?!
Received 3,100 Likes
on
OK, i missed the part about 2 pumps. how about a partially plugged radiator??this will let coolant from the engine into the radiator through the top hose, but not enough through to the bottom hose to cool the engine properly. then when you shut it down, the pressure equalizes and it does not spit out the cap anymore when cold. you should see if there is a radiator shop nearby that can flow test the radiator and cooling system.
on
1 Post
Originally Posted by Racerguy
A 1995 Ford van that's not an Aerostar and has a 3.8L engine in it, with the problems you have, probably needs new head gaskets.
It's a very common problem
Mom was driving home ther other day and noticed the van was blowing smoke out the exhaust. She was almost home so she pulled into the driveway and shut it off. My dad started it later and it was still smoking. Guess the head gaskets are totally gone.
My dad is not sure if he wants to fix them or just replace the whole engine. It has around 220,000 KILOMETRES on it. Van is in rough shape. Not really worth fixing up.
-Matt
Truckerswife
39
05-08-2015 07:06 AM
Beast12
10-03-2003 11:41 AM
