Disable A4wd on 2001 Expedition 4x4? - Page 9 - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
  #121
Old 12-20-2017, 05:24 PM
obxgigi
obxgigi is offline
obxgigi is starting off with a positive reputation.
I really need help
I have a 2001 Ford expedition and I was taking my 5 year old to see Santa. I was backing into the parking space and the truck stalled out. When I started it back the 4 wheele drive was engaged and wont disengage. I have replaced the fuce, reset the computer, and checked all the wires. Please help me. Once I get it disengaged I want to know how to cut the system. I live with A LOT of sand no snow. If you can help please email me at [email protected]
  #122
Old 12-21-2017, 10:48 AM
alloro
alloro is offline
alloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud of
If you pull the fuse the front driveshaft should lose power. The forward clutch is electric, not mechanical.
  #123
Old 07-09-2018, 10:29 AM
Slopitch's Avatar
Slopitch
Slopitch is offline
Slopitch is starting off with a positive reputation.
My '97 Expo has 2H, A4WD, 4HI, 4Low option. Why would you need to disable the A4WD part of the switch?
  #124
Old 07-09-2018, 02:18 PM
pdqford
pdqford is offline
pdqford has a very good reputation on FTE.pdqford has a very good reputation on FTE.pdqford has a very good reputation on FTE.
Because not all years have the 2H position.
  #125
Old 07-12-2018, 01:21 AM
Bootlegger's Deluxe's Avatar
Bootlegger's Deluxe
Bootlegger's Deluxe is offline
Bootlegger's Deluxe is gaining momentum as a positive member of FTE.
my 01 Expy wasn't blessed with the 2 Hi option set. so it drops in and out of 4wd constantly as i drive it down the highway. absolute gas mileage killer.
  #126
Old 07-12-2018, 08:35 AM
alwaysfords41's Avatar
alwaysfords41
alwaysfords41 is offline
alwaysfords41 is gaining momentum as a positive member of FTE.alwaysfords41 is gaining momentum as a positive member of FTE.
It shouldn't be dropping into 4WD on the highway. It only drops in when it detects wheel slip when operating properly Your mileage sucks because your mileage sucks. .
Watcher58
10-23-2016 12:50 PM
78Puller
Projects
31
08-11-2016 10:03 PM
carltonwebb
07-31-2016 02:17 AM
underdogl3
02-18-2016 08:00 PM
Quick Reply: Disable A4wd on 2001 Expedition 4x4?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
