315/75/16 or 16.5x12.5
16.5 is a bead lock wheel I beleave. So it is more likely to come off the bead with lower air presure. (very low) The guy at the tire shop said that they will be fine down to about 20 psi. Thats what I run in the sand if I haul a trailer. He said He drove around town for a day with them at 20 psi with no problem.
Sorry for my rambaling but in short the 16.5's would be more prone to come off the bead.
Justin
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=4920&.jpg http://66.179.41.42/gen1/build/realgeneral.jpg
2002 F-350 SC LB 4X4 6SPD PSD. 3.73 gears. 2.5" leviling kit. Rhino lined Bed. Prodigy trailer brake controler. 35x12.5x16.5 BFG A/T. 16.5x10 ultra wheels.
Justin
a 315/75/16 is the metric verson of a 35x12.50x16.5. i have a 02 f250 with a 4" lift and run the 315's. if you plan on lifting and running a larger tire then a 315 or 35 i would recomend you go with the 16.5" wheels just because there are alot more tire options. i'm not sure but you might be able to get a hevier ply tire in the 16.5" because it's been around alot longer.
lt dan
01-25-2019 01:08 PM
Shwan_89HD
34
04-01-2015 07:16 AM
queen of spades
15
10-06-2013 11:41 PM
xxxcre10xxx
13
12-15-2002 12:13 AM
