what stock FE did this cam come in?
Old 01-19-2004, 07:50 PM
4WD67F250's Avatar
4WD67F250
4WD67F250 is offline
hello, I was digging thru my old ford parts pile and came across a camshaft for a FE engine. my question is what was it out of? IE: 352 360 390 and so on... it doesn't have any numbers or letter combos that I am used to seeing near the last journal, just FOMOCO (printed/casted) not in coursive casted into it. and it has two bumps on each side out closer to the bearing surface. no stripes of color anywhere and no other numbers that I can see.
the reason I ask this is somewhere in that pile of old cams is a 390GT/428 cam and I cant remember wich one it is. I would like to use it in my truck if I can identefy it.
Old 01-19-2004, 08:51 PM
baddad457's Avatar
baddad457
baddad457 is offline
You could mic the lobes to see what the lift is. I've done this several times to ID factory cams.
Old 01-19-2004, 10:18 PM
4WD67F250's Avatar
4WD67F250
yeah, I spent most of the afternoon looking for my mic, it wasnt put back where it belongs... my fault. well there is a few more to dig thru maybe I'll recognize it, some are taged. this one looks to be like a 390 2bbl cam... but its hard as hell to tell without measuring. thanks anyways.
Old 01-20-2004, 06:17 AM
baddad457's Avatar
baddad457
I use a dial caliper to mic mine. Works really well for this. Measure the high side and the low side then subtract for the difference. According to my books the GT cam was colored light blue on both sides of the # 3 journal.
59flatbedford
03-15-2012 06:48 AM
drew.law
01-23-2011 05:23 AM
nofortunateson
11-30-2007 09:38 AM
Paco
03-14-2005 06:15 PM
ford390gashog
21
07-03-2004 01:23 AM
Quick Reply: what stock FE did this cam come in?
