MAJOR ANNOUNCEMENT Predator For 6.0L
#752
I agree...
I have the exhaust, but not the intake...
have even done the Zoodad mod which lessened the smoke some, but not completely...
HOWEVER, if you're not smoking a bit...how do u know if it's getting enough fuel to make all the power you wanting to make :-)
at anything less than VERY "spirited" acceleration it doesn't smoke at all...
#753
Sure "Check earlier post"
I drive F-350 6.0. I've been running the 65hp for a couple of months now and every time my lead foot goes for it your've got the black cloud for a short time. The only person it bothers is the guy you left parked in it. I'm not sure of the post that covers this topic but I read it sometime it the last week and although at first the black cloud was kind of making me wonder if I had a problem thanks to the great input from the folks on this site my mind was put to rest. Not being a pro from Dover I won't try to give you the full explaination that was given. However I'm sure you can do a search and find the straight scoop. undefined
#755
Originally Posted by SBV45
I am running the 65HP program on my F250 SD 6.0L PSD. I notice I get a belch of black smoke at the start of rapid acceleration, but not WOT. I mean I am not really pushing it.
Anybody else notice this? Is it normal? I would expect it at WOT or with the 100HP prorgram.
#758
#759
Bob, I think he has an 04 engine. I believe 9/30/03 was the cutover to the 04. I don't know if the 04 original factory tune will have PI or not. Seeing how they turned it off with the Oct flash on the 03's I doubt it. 04 have a different FICM and therefore a different flash.
TIMM BALDAUF, I would call DiabloSports and ask them. Or call Motorhaven and ask them. Both are very helpful.
#760
#761
Bighoss 550 I have the predator installed on my 550. It's an 04 and I run the 65 and 100 horse programs. I've installed turbo boost, pre & post turbo pyrometers, oil temp, and even an hour meter . The only glitch I've noticed is that with the 100 horse program running and the motor turning past 2 grand the A/C clutch will not engage so there's no cold blow.
#762
BOY, is that eeking out the last bit of HP ?!?!!?
YEARS ago I bought a vacuum switch that if at full pull it would turn off the power to the compressor... A/C would still blow and unless I was at full throttle for 10 minutes or so, it would still blow cold... but it actually gave my little 4 cylinder turbo a boost !!!
Funny if Diablo is doing that electronically - I've not noticed that though... and some of my trips I've been WELL above 2K rpms for HOURS with a LOAD in the back of the Ex....
#763
Originally Posted by Choctaw Bob
I wish Ford would give us better information about this.
#764
i wont be in the 100hp mode often, so its ok. the engine is always above 2000.
btw, how much temp drop do u see across the turbo? and do u have exhaust, intake, etc.?
#765
