fouling plugs
Old Jan 9, 2004 | 10:48 AM
dant's Avatar
dant
fouling plugs
I have a 89 f150 302, when it get cold out like below 30 it will start up and Immediately floods out. If i don't floor the gas as soon as it fires to clean it out it will foul out like 3or 4 plugs. It is very intermitant and it started doing this last year. I have replaced coolant sensor and the air temp sensors it is not giving me any codes. It seems like it runs way to rich. What could be the problem?
Old Jan 9, 2004 | 02:06 PM
90f150moneypit's Avatar
90f150moneypit
The fuel pressure regulator....also this will take the O2 sensor out as well.
Old Jan 10, 2004 | 05:46 PM
tjones1966's Avatar
tjones1966
I had a very similar problem on a 302. After several trips to the auto parts store and to the mechanic a old fellow gave me the right answer. The carburator was dumping way too much in the engine causing the fouling. It took a carb rebuild to solve the problem. Wish I had known before the 20 or so sparkplugs.
