No Cigarette lighter
Old Jan 8, 2004 | 05:34 PM
my79f's Avatar
my79f
no cigerrette lighter
do most of the 73-79 trucks not have a cigerette lighter. cause mine doesnt and i was just wondering if it was anything speacial or not. plus i was thinking how a cowl induction hood would look on one of these trucks so if anybody has a picture of one that they would like to share i would greatly appreciate it.
Old Jan 8, 2004 | 05:48 PM
rainbowATF's Avatar
rainbowATF
cig lighter
Have 1979 F100 Custom 302/C-4, Std Interior. NO A/C, but has Gauges, AM Radio, and Cigarette Lighter
Old Jan 8, 2004 | 06:01 PM
Mil1ion's Avatar
Mil1ion
Most trucks of this vintage had them.
no big deal to install either.
Old Jan 8, 2004 | 07:16 PM
slothshady's Avatar
slothshady
how would you go about installing one of those bad boys, cuz my truck doesnt have one either... just the silver spot where it should be.
Old Jan 8, 2004 | 07:27 PM
brown 4x4's Avatar
brown 4x4
Pop out the silver plug, and install a lighter socket. There's even power right behind it. Look for a wire with a three hole connector, that's the factory plug for the lighter harness.
edit: I just realized I have the light group, and am supposed to have a glove box light which plugs into that same harness. I don't know if all trucks will have that plug or not.
Old Jan 8, 2004 | 07:32 PM
slothshady's Avatar
slothshady
aww man i dont have a glove box light... so im sure it would be more difficult. well thanks for the reply anways
Old Jan 8, 2004 | 07:34 PM
brown 4x4's Avatar
brown 4x4
Check for the plug anyway...I'm curious whether they all have it or not.
Old Jan 8, 2004 | 07:35 PM
slothshady's Avatar
slothshady
yeah, dont get me wrong... i was going to check anyways, i would like to have a lighter outlet. what did you use to pry the silver thing out with?
olfordsnstone's Avatar
olfordsnstone
I filled that hole with a manual choke **** when I converted to a manual choke. I don't smoke and think cell phones belong on the side of the road though.
Not sure but I think that you can buy an aftermarket lighter at the help section of any auto parts store. If not, look in a wrecking yard. Shouldn't be too hard to put in. You could look under the dash for the correct wires to plug in to too.
Old Jan 8, 2004 | 07:38 PM
slothshady's Avatar
slothshady
im not to good with wiring, i wouldnt know the first thing to do if i had to wire it up myself...
Old Jan 8, 2004 | 08:10 PM
Mil1ion's Avatar
Mil1ion
The main harness already has a 90* elbow connector to the lighter.
The glove box light was included in the Convenience/Light group package & therefore an option.
If any of you are looking a quick and easy way to get this stuff,please contact me through the FTE e-mail system.
This should help as well.
The 14A009 wiring harness is the lighter plug/wire
You can see this by looking in the middle of the illustration and count the 3rd set of text up from the bottom.
http://www.clubfte.com/users/mil1ion...ingharness.JPG
Old Jan 8, 2004 | 10:59 PM
LxMan1's Avatar
LxMan1
Here is the only Cowl hood that I have seen for the 73-79 Trucks. http://www.up22.com/ranger.htm#FD-794
I would probably look pretty good on mine
Jimmy
Old Jan 9, 2004 | 01:51 AM
plowpusher's Avatar
plowpusher
look for a yellow wire under the dash by the ash tray it has a 90 degree elbqw like the wires going to your starter solinoid its there you just gota find it thats the power wire for the lighter the run a seperate ground to the flat tang on the lighter
Old Jan 9, 2004 | 01:34 PM
ivanribic's Avatar
ivanribic
Don't you know . . . cigarrettes will kill you! They are now referred to at '12 volt power receptacles'. I say with all the modern toys out there you can never have too many outlets. I'm going to install a few in my center console when I put it in.
Old Jan 9, 2004 | 06:43 PM
my79f's Avatar
my79f
wow thanks for the replies. i think that i might look into the cowl hood deal
