Changing Shifter Knobs
Ron
I don't understand what you mean by an "automatic shifter **** with a button like the Aerostar's." What button? I assume you're talking about the column shift selector lever and I believe you have to remove the steering wheel and related parts to get to it.
Ron
According to my Chilton's it's easy to remove the shift handle and shift rod. First, emergency brake on, wheels blocked and shifter in neutral.
Remove interior panels and components around the shifter rod and carpet around the shifter seal.
Remove the rubber shifter boot to access shifter seal plate attached to floor.
Remove bolts securing shifter plate to floor and remove plate to expose top of transmission and shifter.
Remove four retainer bolts securing shift rod to transmission assembly and lift plate and shift rod out.
To install apply multi-purpose long life grease to ball end which installs into transmission, install shift rod into transmission and torque retainer bolts to 6-9 ft lbs. Reinstall all parts removed previously.
Hope this helps.
Ron
razor_jim has the old floor shifter with an automatic transmission. You gave the directions for the 5-speed. Here is what Haynes states for removal.
1. Under the vehicle, remove the retaining clip and disconnect the shift cable from the selector lever.
2. Inside the passenger compartment, grasp the floor carpet center retainer securely and pull up sharply to remove it from the base of the lever assembly.
3. Remove the four retaining bolts and lift the selector lever assembly from the vehicle.
4. If it is necessary to remove the selector handle and button, grasp the handle securely with the shifter in Drive and pull straight up. If the handle does not come off easily, tap from below with a rubber mallet. To install, place the handle/button in position, making sure the handle chrome ring is lined up with the selector handle groove. Strike the center of handle with a rubber mallet until it is seated.
5. To install, place the selector assemble in position and install the bolts. Tighten the bolts securely.
6. Place the carpet retainer in position and press down evenly until it snaps in place.
7. Under the vehicle, connect the shift cable to the selector lever.
8. Adjust the linkage.
I would suggest you invest in either the Haynes or Chiltons manual. It’s worth the price. I have both. I got the Chiltons used off of Ebay.
Thanks for the clarification. I thought I might be wrong as the directions I gave didn't indicate anything about a spring operated release mechanism. That's why we all work together.
Thanks - Ron
razor_jim,
As Tom indicates you can easily remove the handle and button; whether or not your replacement will fit is another question.
From Tom's post:
"4. If it is necessary to remove the selector handle and button, grasp the handle securely with the shifter in Drive and pull straight up. If the handle does not come off easily, tap from below with a rubber mallet. To install, place the handle/button in position, making sure the handle chrome ring is lined up with the selector handle groove. Strike the center of handle with a rubber mallet until it is seated."
Ron
razor_jim,
Ron
.......new one needed to be seated firmly or selector would not go into gears....rick
