Shift points
Old Dec 31, 2003 | 10:03 AM
No_BS's Avatar
No_BS
Shift points
I'm just wondering, I think that with my larger tires my tranny would do better if I could change it's shift points to slightly higher RPM's. It's an E4OD, so what has to be done to do this?
Old Dec 31, 2003 | 10:42 AM
StrangeRanger's Avatar
StrangeRanger
Either a re-programming of your PCM or an add-on chip. With a stock engine, the shift points are pretty much optimized from the factory. Rev it higher and all you're likely to make is noise. To offset the bigger tires, you need bigger gears. That's expensive on a 4X4. "Plan B" is to build the engine up a bit to make more torque.
Old Dec 31, 2003 | 12:35 PM
EPNCSU2006's Avatar
EPNCSU2006
Have you changed the tire size in the electronic speedometer? I don't know if that has anything to do with it, but it might be something to think about.
Old Jan 1, 2004 | 12:31 PM
No_BS's Avatar
No_BS
My speedo's not electronic, I'm not really wanting it to rev higher, just there are times where I'd like it to downshift or not upshift, I don't hove $ for gears so I guess I'll just keep doing creative throttle work.
