Long tubes and emissions
Old Dec 26, 2003 | 11:11 AM
dbuck50's Avatar
dbuck50
Is it possible to get long tubes that will work with emissions stuff? I would like to get coated long tube headers that will work with a high flow cat...what type of crossover do I need? I don't really want to run true duals. Can I buy this stuff out of the box or does it require a lot of custom fitting?
Old Dec 27, 2003 | 10:27 AM
WhëëlMå1's Avatar
WhëëlMå1
You are talking about complete custom components when you go to long tube headers. It is very difficult to get a Y pipe to work with them, and still be street legal (ie cats and sensors). Is there a reason you want long tubes? Have you thought about equal length shortys (better than regular shorties)? I am running a pair of Bassani ceramic coated equal lengths on my bronco. Most guys run true duals (illegal in most states) when they go to long tubes.
Rich
Old Dec 27, 2003 | 03:00 PM
dbuck50's Avatar
dbuck50
No, I was thinking equal length. My only reason for thinking long tubes was that I understand that they provide better low end torque which would be great with my 302. I also understand that shorty's can lower your existing manifold setup torque for lower rpm and increase it over 5K rpm...that wouldn't be good. Are equal length shorty's a compromise between the 2? what kind of difference did you notice with your bassani's and did you use their Y pipe too? Any problems with the bolts backing off or not being able to get to the spark plugs?
Old Dec 27, 2003 | 03:09 PM
WhëëlMå1's Avatar
WhëëlMå1
Yes, there is no doubt that long tubes provide much better low end torque. They are a hassle though, like stated previously. I have noticed a slight loss at low rpms, but the passing power and get up and go from mid rpm ranges make up for it in my opinion (this thing would rock if I had 4.10 gearing). Yes, equal length are the best of both worlds. I have their ceramic headers, high flow Y pipe, and catback. I have had all of this installed for a good six months now, and not one bolt has backed off. I havent had to change plugs yet, so I cant tell you. It wont be easy, but it can be done with patience.
Rich
Old Dec 27, 2003 | 04:48 PM
dbuck50's Avatar
dbuck50
How about noise inside the cabin? I really am not looking to make a lot of racket (or hear it), did you notice a big difference? Bummer about losing that low end torque.
Old Dec 27, 2003 | 05:00 PM
WhëëlMå1's Avatar
WhëëlMå1
The only increase in noise that I have observed is from the actual catback. This would be vehicle dependant though. I own a bronco, so I am basically sitting on top of the muffler, whereas on a pickup truck, it is behind you many feet.
Rich
Metallicfire
Jan 30, 2014 08:37 AM
burton7.3
Jun 10, 2013 02:10 PM
Brandonsf250
Aug 28, 2012 12:25 PM
Rbalkema
13
Jun 25, 2012 07:51 PM
oneofakind97
Exhaust Systems
Apr 24, 2008 11:19 AM
