Water pump removal
Old Dec 20, 2003 | 10:29 AM
Flaflathead's Avatar
Flaflathead
Water pump removal
Hello everyone!, Question, I have an F-1 and will be replacing the two water pumps. The truck originally had a 6. A V8 flathead was installed. As it appears, the pumps are part of the motor mounting to the frame. Is there an easy way to change the pumps, or should I just block and raise the engine up?
Thanks for any help, Monte
Old Dec 20, 2003 | 10:55 AM
4tl8ford's Avatar
4tl8ford
You have to block and raise the engine.
There is a bolt INSIDE the water outlet, don't forget to remove it.
Old Dec 20, 2003 | 12:30 PM
barry's Avatar
barry
Make sure when you replace that bolt inside the water pump outlet, put anti-sieze on it.
barry
50 F-1
Old Dec 20, 2003 | 05:06 PM
Flaflathead
Thank you Dick C and Barry!
