Half front wheel cylinder for F-250
Bill,
I don't recall the part number, in fact it was my local parts store that brought it to my attention. The only other thing I needed, besides the wheel cylinder was another little fork shaped push rod that goes between the piston and the shoe. As I recall, the parts guy wanted a production date on my truck because it showed two different types, the single-piston and the dual-piston. Fortunately for me the single piston was not available. He even had the fork-shaped thing.
Ordered mine through johns f100. Spoke with a woman named Diana. Still haven't received them, though they knew exactly what the difference was and what I needed. They're on the web.
www.johnsf100.com
HTH.
Bob
www.johnsf100.com
HTH.
Bob
Well, here is what I ended up doing.
I used the front cylinders for a 61-64 4X4, all one has to do is to drill one 5/16 hole in the brake mount plate. The old half cylinder mount holes are a diagonal pattern, where as the double holes are strait in line. now you can bolt on the dual cyl, then just buy two more link pins and it is ready to go. have good strong front brakes now. Then all I need to do now is to play around with the adjustable pressure valve to get the front and rear to grab even.
Now I am not at the mercy of looking all over for an obsolete part.
CTom
07-07-2014 03:21 PM
Deadeye1963
08-31-2004 05:43 PM
