Diesel Fuel Additive road test results
#47
G Chavez
I got some stuff called Power kleen from Wal-mart and put 16oz in. I'm hoping that I can find some Diesel Kleen at a near by Truck stop.. I will let you know how this stuff works out. The Bottle said that it will up the certane 4 points.
I do love my truck very much, I don't think that I will every have anything but a PSD..
Thanks again for the help.
DR JOE
DR JOE
#48
Power Service makes the Diesel Kleen DFA. They make two versions that I know of, white bottle and grey bottle. Looks like the white bottle has some anti gelling additives for colder climates and increases the cetane "up to" 4 points (depending on the mix ratio). The grey bottle claims to increase performance and cetane levels "up to" 6 points. Sounds like you might have the white bottle, which I think is similiar to the Rotella stuff I used with mild results. Keep your eye open for the grey bottle, I found the 96 oz size at a regional truck stop called "Flying J". They had plenty of the white bottles on the shelves, I had to specifically ask for the grey bottles. The clerk went to the back stockroom and came back with 3 jugs, I took two and he put the last jug on the shelve. It sat there for about 10 seconds before someone snatched it up. The clerk said the grey bottles are the most popular by far.
#50
just my .02 I have a 01 f350, crew, 4x4. 3.73 rear end. i only get average 13.5 mpg. I have a chip and stinger system and have done the fuel tank mods but to no avail. Also, I use the stanadyne with each fill up. )didnt do much good yesterday. cost me a hundred bucks to have ford thaw out my system after we had single digit temps. anyway, I have talked to others and it seems that everyone I talk to with the exception of those on this site get about the same milage as I am. could it be a difference in which part of the country you live in?? I live in Idaho as just wonder if the altitude has anything to with it.
#52
I love the DK grey bottle...use it all the time. I do think as gburkett has said that it depends on the part of the country your in. I don't know that altitude and temp have as much to do with it as quality of fuel. with fuel very from station to station , I'm sure that it does even more so from differnt parts of the country. Some places have a greater amount of centane to begin with. all have minimum standards, but where some are just meeting those, I bet some are exceeding them. with those places where the fuel is at the minimum, the DK has got to help. After a some point, I would think Centane boost is overkill. For example if Texas fuel is at the min, but California exceeds it by 5-7 points, those in California would see little to no benifit of DK, while those in Texas would think it was the next best thing. I know personally, it has made mine run better, better throttle response, better mileage, and smoother. I know some on here swear its snake oil, but because its helped me, for the price I will continue using it.
as for those who have tied it once or twice and gotten worse mileage, is it possible that cleaning the injectors has clogged up something and it needs a tank or two to clean everything out? This could give you a tank or two of bad mileage, and then get you up. Don't know, but I would be interested in somebody that has had a bad experience to try it for several tanks to see if it makes a difference.
#53
I have found that if non-gelling is what you want you better use the white bottle. The grey bottle is a blend more to help lub and clean.
What I do have question about is: does this stuff attack regular plastic pop bottles..?? I like to pre measure mine and the 16 oz plastic bottle with the screw on lids are great, but I don't know for sure if the DFA attacks the plastic. It doesn't seem to.
Can anyone answer that question..???
#54
Take a look at the bottom of both bottles and see if they are marked. If both are #1 or #2, you should be good to go.
If in doubt, put some of the additive in the soda bottle and let it sit for a while. See what happens.
#55
#56
#57
I am now running Stanadyne. My truck has one of those didgital MPG displays and when I dumped in DK I lost about .4 mpg. Other than that no difference in engine sounds or performance. Now that I am buying #2 diesel and putting in a 16oz bottle for every 55 gallon drum I hope my mileage goes back up. Just filled the drums today. Stanadyne better make the gelling stave off to at least -40f. Otherwise I'll be screwed. It claims it lowers it by 40 degrees and the #2 here is good to -10.
How does Stanadyne do? Anyone run it. I know some people on here do.
#58
Hey guys thanks for the input about the plastic bottles.. I put some in a green Mountain Dew bottle (green for Diesel) yesturday. It doesn't seem to be bothering it. I'll give it a longer test (maybe a week) before I consider it safe. That is unless someone else has some input.
I didn't see any numbers on the bottle as far as recycling goes.
#59
