Question here? My temp gauge doesn't work and I need to know what to do to fix it? Problem is the repair manual lists two different sending units for the 300 EFI motor. One is mounted in what is probably the worst location for a sending unit: the underneath the intake manifold near the very back of the block (where you can't reach it). The other sending unit is on the thermostat housing. Question is which one or do both send a signal to the temp gauge. Or what? I want my temp gauge fixed so I don't have to take the thermostat out during the summer months when outside temperatures are in the 100s. Please help anyone who know which one is which?
The one for the gauge is the one on the back of the engine, up underneath everything. The one on the top of the thermostat housing is for the computer.
How do you test the resistance values and what are the values I should look for? I have a multi-tester, but what should I set it to and what numbers am I looking for?
I have my custom guage sender were the CPU sensor was. Will that effect anything? The engine seems to run, but has no highend power, could this be the cause?
Ya'll are forgetting something. My Engine is EFI, and have a very large and annoying intake manifold in the way of everything. Remember it wraps around from one side of the engine over and across the top of the valve cover to the other side where the air intake hoses are. How do I reach it with the manifold in the way?
Thats how I changed mine. it took about 10-15 min tops. Just have the new sender ready to stick in right away because you will get bathed in antifreeze.
