Dual exhaust
Old Yesterday | 03:50 PM
Rick519's Avatar
Rick519
4wd Low
Dual exhaust
86 f150 with 5.0L 2wd going to be installing daul exhaust wondering if i should go with 2.5" or 3" pipe plan on using flowmaster 40 mufflers?
Old Today | 07:31 AM
Olds64's Avatar
Olds64
Have you been to a local exhaust shop? Probably there would be an undetectable power gain with 3" vs 2.5" exhaust. At least using a butt-dyno.
Old Today | 09:15 AM
PROSTOCK's Avatar
PROSTOCK
Duals/headers on a 302 probably isn't going to buy much, perhaps better MPG. For a stock or even a mildly built 302, 2 1/4" duals is all that is needed, 2 1/2 or larger wont buy you anything. You'll have a good chance of having an annoying drone with 40's. Straight out back or side exit? If side, in front of rear tires or behind? That will have some impact on the noise level inside the cab. IIRC 40's are pretty short so if/when you decide you've had enough, there should be enough pipe to take those out and add larger mufflers.
An '86 is fuel injected, no? If so you have at least one related detail to deal with, O2 sensor(s). Hopefully you can get that to work nicely with your ECM. I'm sure others have done this who may chime in.
Good luck!
Old Today | 11:35 AM
kenny nunez's Avatar
kenny nunez
Dual exhaust
Just be sure to add a balance pipe which may quiet some droning.
Old Today | 12:04 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
dual 2-1/4" plenty for stock or mild 302
Old Today | 03:12 PM
Franklin2's Avatar
Franklin2
Have you looked underneath at your truck? Not much room for duals, they have to both be run on the pass side and then cross back over if you want one to come out on the driver's side rear.
Matt1966
Oct 12, 2023 05:30 AM
Neirti
Exhaust Systems
19
Aug 14, 2008 01:45 PM
zuikoman
Exhaust Systems
Oct 24, 2004 12:02 AM
