Another Intake Question
Old Yesterday | 07:39 PM
Jtsarby's Avatar
Jtsarby
I am working on my 96 build. I have AFR 165 heads. I was porting my lower intake today to match the heads. Unfortunately the carbide bit slipped and put a health gouge in the mating surface of the intake. It is toast. I am looking around local for a lower and have found a few explorer upper and lower. I have tried everything including searching different forums for an efi 302 that has explorer/gt40 upper and lower intake to do some research. I know the stock truck intake produces the best low end torque but I have read the explorer provides better top end and still give decent low end torque. Here is what I am looking for. 1. For those who have made the swap, how did you route everything? I have ford performance valve covers. Will the explorer intake clear the taller covers? I have found a few that have the upper, lower, throttle body, and elbow. The air intake hose will have to be routed differently as well. Any advice? I am going to go to the JY on Tuesday to see if they have a stock lower. The photo is of one I found on marketplace but it is an explorer upper and lower
Old Yesterday | 08:13 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I cannot answer that question but I have AFR Renegade 185 stud mount heads. I was going to use the hybrid truck 5.0L upper/ 5.8L lower but it wouldn’t clear the taller cable covers.
Old Yesterday | 08:29 PM
90project5.0's Avatar
90project5.0
https://www.cjponyparts.com/trick-fl...yABEgKOKvD_BwE
Theres always this to be on the safe side, plus it would help get back some of the low torque you would lose.
Old Yesterday | 09:10 PM
Jtsarby's Avatar
Jtsarby
My main concern is how to route the air intake and throttle cable. Also the tab tad solenoids are on the driver side. The gt40 upper overlaps the driver vs the f150 stock upper is on the passenger side.
Old Yesterday | 09:17 PM
90project5.0
Thats interesting, all the ones I saw on explorers in JYs had it going over the passenger side. I know you can flip the upper to opposite sides.
as for the intake tubes, definitely going to be a custom since it uses a single bore throttle body.
Old Yesterday | 10:09 PM
Scndsin's Avatar
Scndsin
Post a picture of this gouge how bout?
Old Today | 08:43 AM
dremtofford's Avatar
dremtofford
how can you tell they are gt40 heads? is there markings on them or do you just take someones word for it. i have stock heads for an 88 302.
Old Today | 08:58 AM
90project5.0
GT40 heads with have “3 bars” on the front of them. GT40p heads have 4 bars. They are not stock on any F150.
Old Today | 09:03 AM
1Butcher's Avatar
1Butcher
I am not a fan of JB weld, but I bet a well prepped surface will hold the glue and once everything is bolted up, it will seal fine.
Old Today | 09:54 AM
rwfid's Avatar
rwfid
Even if the gouge is bad enough that the gasket won't seal it, the manifold would still be easily repairable if you can find someone that can weld aluminum. Preferably TIG welding.
Old Today | 11:33 AM
Jtsarby's Avatar
Jtsarby
All heads have a manufactured stamping in them that identifies what type they are. You probably have E7 heads, which is what was stock on most 302’s.
Hit Man X's Avatar
Hit Man X
5.0 Explorer intake is just a 90s Cobra Mustang intake without EGR as I recall. I would have kept the truck one until the thing runs.
I had a Cobra intake on a 5.0 before, it will not rev to the moon...look at the runner length. 100% better than the stock H.O. unit
What camshaft are you planning? Definitely will rip with those heads and either intake.
Old Today | 03:21 PM
dremtofford
yes i have the e7 stock heads. is it worth it to put the gt 40 heads on. i won't be doing any high speed driving with the 4wd and manual trans.
Old Today | 04:23 PM
90project5.0
Its worth it if you want more power.
1ole4d
Nov 11, 2022 06:58 PM
FordYoungGun35
Sep 18, 2012 08:57 PM
Jrock909
Feb 22, 2007 04:08 PM
Jrock909
Jan 3, 2007 10:28 AM
Shinoda
Jan 1, 2004 12:34 AM
