noisy belts
Old Dec 10, 2003 | 02:09 PM
BVFD1983's Avatar
BVFD1983
noisy belts
I replaced the belt on my 98 3.0 a few months ago due to the old one squeeling. The noise has came back. My dad told me not to use belt dressing and it is only temporary anyways. This sucks. I sound like a jackass driving around with that noise. It only does it under 1500 RPM though.
Old Dec 10, 2003 | 02:29 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Is the belt tensioner doing it's job or is the spring in it weak? Also, have you checked for proper belt alignment? I assume it's the correct belt and there is no chance whatsoever that it might be the wrong length. Also, is there a componenet failing, such as a bad bearing, and the belt is slipping/sliding over it? Just my thoughts.
Old Dec 10, 2003 | 03:14 PM
BVFD1983's Avatar
BVFD1983
Shouldn't be. 66,000 miles. The belt was fine until last week.
Old Dec 10, 2003 | 06:47 PM
Ken00's Avatar
Ken00
I would start by cleaning all the pulleys and testing the belt tension. DON'T use belt dressing.
Old Dec 10, 2003 | 11:46 PM
BVFD1983's Avatar
BVFD1983
Can I just spray some contact cleaner on them or do I need to remove the belt and physically wipe/brush them.
Old Dec 11, 2003 | 10:55 AM
Ken00's Avatar
Ken00
I would wipe them.
Old Dec 11, 2003 | 11:06 AM
BVFD1983's Avatar
BVFD1983
Can I use contact cleaner?
Old Dec 11, 2003 | 01:30 PM
Ken00's Avatar
Ken00
Check out this post, it should answer all your questions.
Cleaning post
Old Dec 11, 2003 | 05:33 PM
AKranger's Avatar
AKranger
I had the same problem with a Buick. I must have used a pint of belt dressing. It didn't hurt anything but it is just a very temporary fix. A little extra tension did the trick.
Old Oct 3, 2005 | 07:49 PM
frdrngrlvr's Avatar
frdrngrlvr
i've used a quarter can of belt dressing but isn't really helping anything. how do you create more tension? replace the tensioner?
Old Oct 3, 2005 | 07:51 PM
frdrngrlvr's Avatar
frdrngrlvr
hey ken00. whats so bad about belt dressing?
Old Oct 3, 2005 | 08:17 PM
Ken00's Avatar
Ken00
A squeaking belt means something is wrong, it's just a bandaid.
Old Oct 3, 2005 | 08:22 PM
AKranger's Avatar
AKranger
frdrngrlvr: I simply tightend the belt by loosening the adjusting bolt and prying with a bar to get the belt within specs.
Old Oct 3, 2005 | 08:23 PM
Ken00's Avatar
Ken00
Just an FYI, were talking about a serpentine belt not a V-belt.
Old Oct 3, 2005 | 09:17 PM
handyman43358's Avatar
handyman43358
I sprayed some belt dressing on a belt once, fired it up, next thing I know I'm buyin a new belt. Ripped it to shreds!
