Engine Refresh
Old Apr 3, 2026 | 01:04 PM
akblackfoot's Avatar
akblackfoot
Engine Refresh
Haven't been on here for a very long time but my 6.0 has just been pluggin along with just regular maintance issues. Replaced all injectors recently after 300,000 miles. Some of the injectors were original but I'm not 100% sure how many since I bought it used. I'm scheduling it to have an almost complete teardown to replace lifters, reseal the bedplate and front cover, etc. I'm curious if there is any solid data out there on how long a HPOP can last? It's a 2006 and I previously had the updated stc fitting done 150,000 miles ago. Torque Pro is showing I hit 4,000 PSI at around 75% IPR on a stock tune and it idles at well over 500 PSI. Should I just replace the IPR or would it make sense to replace the HPOP with a new OEM while in there?
Old Apr 5, 2026 | 07:11 AM
BLADE35's Avatar
BLADE35
Originally Posted by akblackfoot
. Torque Pro is showing I hit 4,000 PSI at around 75% IPR on a stock tune and it idles at well over 500 PSI.?
High end HPO numbers look good
It could go another 100k or more who knows
to me it would be a thing of wether or not i want to change down road and separate cost IF paying a shop to do the work
how’s the oil cooler numbers
Whats about turbo?
uppipe flex joints still ok they tend to crack and leak
Old Apr 5, 2026 | 07:29 AM
bismic's Avatar
bismic
Well said Benny.
Both the y-pipe and up-pipe bellows may be leaking. It is inevitable at SOME point.
Old Apr 19, 2026 | 09:39 PM
akblackfoot
Replaced the y-pipe with BD quite a while ago. Oil cooler numbers are great but the shop replaces them when they do this work.
94.5turbodiesel
Feb 8, 2022 12:30 PM
Rocketgs
May 12, 2017 09:02 AM
JR56F-100
Jul 15, 2015 03:18 PM
jayc3169
Jan 18, 2015 12:51 PM
KRDiesel
Jun 6, 2012 12:58 AM
