looking for clutch replace advice
Old Feb 25, 2026 | 05:24 PM
DaveMcLain's Avatar
DaveMcLain
I recommend a new clutch from Luk too. The Repsets are good and many times you'll replace a long style pressure plate with a diaphragm one that will make the clutch effort much lower and smoother.
Not turning the flywheel can be a mistake no matter what the surface looks like. Over time the flywheel gets pulled into a bowl shape by the pressure plate so check it for flatness using a straight edge and a feeler gauge. If it is out more than a few thousandths have it reground. What happens is the clutch disk gradually wears into this surface and it causes no problems. But when you replace the worn disk with a new one the clutch loads much more or totally around the outside edge of the disk. This can make it work unevenly or even cause it to tear the lining off of the new disk.
Old Feb 25, 2026 | 05:28 PM
elbow grease's Avatar
elbow grease
Thanks alot for the input Dave! Makes sense about the flywheel too.
Old Feb 26, 2026 | 12:20 PM
elbow grease
Thanks to everyone who chimed in, much appreciated. I think I'll just invest in a tranny jack and go that route, I'd like to replace the crossmember anyway. Thanks again!
Old Feb 26, 2026 | 12:36 PM
79F150400M's Avatar
79F150400M
Best of luck! Let us know how it all works out for you.
Stepney
Nov 16, 2017 02:59 PM
Pitweiller13
Dec 10, 2015 04:12 PM
73f100shortbed
Jun 13, 2006 07:54 PM
cptbfp
Aug 12, 2005 09:12 PM
rmcdonnell
Nov 19, 2003 04:25 PM
