Vacuum line replacement
Old Feb 11, 2026 | 02:25 PM
sparklepony's Avatar
sparklepony
I still have what looks like the original vacuum lines on this truck - I have patched one but really want / need a better solution before they all give way.
is there a reference chart as to the length of each required diameter so at least I can try to shop these ?
Old Feb 11, 2026 | 03:23 PM
dlburch's Avatar
dlburch
the part manual lists some specific hoses and for some it just says to cut correct length from bulk hose. Amazon has kits that contain various lengths of 1/8 thru 3/8" hose as well as some kits with various connectors in case any of your plastic tees are also degraded.
Old Feb 11, 2026 | 03:50 PM
sparklepony
thank you - I did find a reference in the vacuum booklet an image of every engine except the 5.8L - I am assuming it is the same as the 5.0 ?
I was thinking that it would be easier to re-trace the lines if they were colored like the factory but it looks like it's going to be all black...
I would also think that after all of this time that the connectors are shot or at least not in prime condition.
Old Feb 11, 2026 | 04:27 PM
Rubiranch's Avatar
Rubiranch
Small vacuum hose is 5/32"
Power brake booster is 11/32".
I think PCV hose is 3/8" fuel line.
Old Feb 11, 2026 | 04:43 PM
dlburch's Avatar
dlburch
Looks like you might be working on a newer truck, but same suggestions still apply.
Wheelman55
Jun 15, 2016 10:37 PM
jimbo285
1978 - 1996 Big Bronco
Mar 22, 2016 05:35 PM
76ClydeF100
Jan 22, 2014 12:15 PM
FordFanboy
May 17, 2013 03:19 PM
BigBlue92
May 24, 2011 10:09 AM
