What gear ratio?
Old Jan 14, 2026 | 05:38 AM
cooperkoh's Avatar
cooperkoh
Trailering
What gear ratio?
i’m looking for a dana 60 for my 86 cclb f350 dually. i want to keep coils if possible. the rear is a 3.55. what gear ratio should i be looking for for the front, the same ratio? any way to keep my coils?
Old Jan 14, 2026 | 07:23 AM
Franklin2's Avatar
Franklin2
You should look for the same ratio. If you want a stock swap in axle, you need to go to leaf springs and get a 1986-1998 f350 dana 60 front axle. That will all bolt in with some hole drilling. If you want front coils, that is going to be custom. But there is a kit made for that in the link below. You would need to find a later front axle and the lug pattern for the wheels will be different. If you go this route you might as well swap in the later rear axle also.
1992-1997 Ford F-350/250 05+ Coil-Over And Front Axle Swap Kit – Sky's Offroad Design
Old Jan 14, 2026 | 08:38 AM
FuzzFace2's Avatar
FuzzFace2
He has a post going on the frame swap to get 4x4 and a 6BT diesel so maybe he is looking to swap this truck to 4x4 first then the diesel?
Will the frame hold up to the diesel is the question?
Dave ----
RedneckRenegade91
Jul 19, 2014 12:14 AM
HILLBILLY BOB
Nov 17, 2011 09:19 PM
BrentNewland
Jul 18, 2008 10:57 AM
WarWagon
Apr 12, 2007 10:54 PM
