What’s the performance difference between plugs on a 292 set at .032 or .040? I currently have them set at .034, starts and runs good.
I always thought older vehicles ran closer gap due to limited secondary voltage (25,000 volts) compared to newer with electronic ignition. I'd say if you are running a hot ignition (40,000 volts) then .040 would be better
I wouldn't get too caught up on the gap as long as you are within the specified range and are satisfied with how things are running. The 0.34 is spot on according to Van Pelt:
Usually the gaps are specified as a range, and traditional wisdom says to try to aim for the smaller side of things as the gap will naturally grow with wear. It is also said that leaning towards the larger gap can lead to better fuel efficiency. A wider gap also can retard ignition timing. I'm sure there is a whole science to this all, but again, I wouldn't get all caught up in it all unless you are racing or similar.
If it ain't broke, don't fix it is always a good rule to follow. The neat thing about plug gap is you can play with it and see what happens with no consequences. It either works better or it doesn't, and you can always put it back if you don't like the results in about 15 minutes.
With the IGN II and III, you will be running hotter coil(s) and can increase gap (hotter/longer spark) as was done with DURASPARK allowing running a fatter fuel curve and a colder plug.
