EGR issue
Old Oct 6, 2025 | 11:20 AM
Ethan’s f-250's Avatar
Ethan’s f-250
EGR issue
I have a 1989 f250 with an 351w and it doesn’t like starting cold. I replaced the coolant temp sensor and the air idle control valve and it ran perfectly for a week. Now when I start it, the idle dumps and the engine stalls out. I replaced the egr unit (the metal piece that attaches to the tube) and it starts intermittently. When I was trying to start it, if I unplug the hose that attaches to the top of the egr, the truck started. If I attach it after it’s started, the idle gets choppy. I have engine codes 34 and 84. Any ideas?
Old Oct 6, 2025 | 03:14 PM
jas88's Avatar
jas88
You should not have any vacuum to the EGR at idle and/or when the engine is cold.
Old Oct 6, 2025 | 04:27 PM
Ethan’s f-250
There is a little bit of suction when it’s idling/cold. Not a lot, but it’s there. How do I make it not do that?
Old Oct 7, 2025 | 12:10 AM
Conanski's Avatar
Conanski
The EVR (EGR vacuum regulator) is leaking, it is the solenoid under the coil facing the front.
Old Oct 7, 2025 | 12:13 AM
Ethan’s f-250
Okay, perfect, I’ll get one of those. Do you know of a place to buy one? I checked autozone/o’rielly/napa and they don’t have any for my make and model truck
Old Oct 7, 2025 | 05:19 AM
manicmechanic007's Avatar
manicmechanic007
You won't
That pulsating (what feels like vacuum is a normal signal from the EGRV) (EGR solenoid)
That solenoid has a cap on it covering a foam filter
The vacuum is constant at the solenoid, and it vents through the foam filter (the processor controls the solenoid) and regulates EGR flow
When the filter starts getting plugged, you have EGR flow at idle and that's trouble
Your hard start cold is not the EGR, no vacuum is present until the engine starts means the valve will be closed / should be closed
luketrot
Sep 18, 2010 05:47 PM
rustee90-150
Sep 16, 2008 07:48 PM
93bigbronco
Dec 10, 2002 07:17 AM
Tdawg123
May 9, 2002 04:59 PM
KTMNealio
May 26, 2000 02:42 PM
