not sure about your note.
eec-Iv have misfire detector some eec-iii. Since 1882-83 sbf.
then 1996 351w cali engines, some obd2
all obd1.
obd2 have crank shaft position sensors, specifically for spark, in conjunction with camshaft sensor, as they do not have a distributor, well some do, , but if you go distributor less, you need crankshaft sensor.
im now interested to know if obd2 crank sensor also detects misfire, I doubt it.
the reason the misfire monitoring via crank is done is for emissions components , the reason for knock sensor is to keep the engine from detonation
Since the engines are old famlies they have distributors and knock sensors from their eras. and the add on crank sensors are regulatory necessity but coincidentally they do a great job for some timing control since its being modified by the PCM anyway
I see no reference to OBDII system, it specifically states OBDI TFI Misfire detection sensor. Yes, TFI happend on OBDII, rarely, then EDIS.
Thats your docs, TLDR;
For TFI, yes the crank has a misfire detector, without TFI, pretty sure it is EDIS and crank sensor.
Either way, who cares, FORD (Henry) dropped the miss/knock whatever you want to call it, cause it doesn't work. We are 40-50 years later in advancement, don't use it.
Tune your engine with pimpx, dont' over rev it, if you do, add fuel, you don't want to go lean. Put your rev limiter to 4000, you'll never(shouldn't) have a problem.
ps. If your worried about rev limiting and knock and you actually don't know about either, its a moot point.
knock sensor doesn't exist on a 351, only some 302 and 6cyl.
Not in a 351, and its a miss fire detector if its got the 4 pronged tone ring, TFI with distributor.
36 tooth tone ring is 302 EDIS no distributor, crank sensor, might have a knock sensor I do not know.
Who cares, I do not know PIMPX, nor do I want to. There's TFI and EDIS, you have miss fire detector or crank sensor.
Yes and no. It plugs right into the factory harness and uses the OEM sensors. The computer skill to tune it was above my ability but there are people on here that have been able to tune it themselves.
Thought it was discussed already, Pimpx well actually TunerStudio knows nothing about knock, you have to tell it, and it works best with GM sensor, that is not OEM.
This would also be above the skill of the regular tuner who thinks Pimpx is Plug N Play, as you would have to program a custom input, and tell it what to do.
I misunderstood your comment about the PiMPx computer not plugging into the factory wiring. Already established is that the knock sensor does little to nothing. I have a 351W so no knock sensor and PiMPX doesn’t use the sensor so why bother to try to get it to work?
no offence white but you usually have a knack for these things and the materials I just sent dont cover all of the OBD2 behavior/stuff I just sent the stuff I wanted to thats relevant. the reason that the stuff there includes eec-iv stuff is that the 1996 federal f250 didnt get compliance with obd2
but california offered no possible way to sell a truck without that compliance , so thats why MAF/Cali 351 and 460 are a common thing that come up a lot.
youre right that the 351 doesnt have a knock sensor.
only a OBD2 1996 or 1997 F250 or F350 will have a misfire detection sensor which is a crank trigger (hall-efffect iirc) on the crank pulley tone ring , but a 1996 F150 all should (gas engine wise)
all of those engines have distributors. you do not find EDIS on a 4.9, 5.0, 5.8, 7.5
That means there is obd2 vehicles with knock sensors as well.
The 1996 f150 4.9 and 5.0 both are equipped with a knock sensor and a misfire detection sensor.
On 1997 F250 and F350 and 1996 as well but only CALIFORNIA eec-v obd2
that will support live data which reads out misfires on individual cylinders.
Again, this is a obd2 regulatory requirement, as in the law. you cannot have obd2 compliance without that functionality
Ford only met OBD2 for F250 and F350 in 1996 and 1997 in california but it
