Reverse lighting light bar
Old Sep 5, 2025 | 01:02 PM
6.2caribou's Avatar
6.2caribou
Has anyone seen a high output/bright, preferably white light only, 60" lightbar, the type that mounts to the truck bed...in the area between the tailgate bottom and the top of the bumper? I'm really not interested in the ones that supplement the brake lights and turn signals. I just want a bright white only light that I can power thru one of the upfitter switches.
The purpose is to improve my reverse lighting while I have our camper hooked up. I use a set of Rock Tamer flaps that mount on my 2.5" receiver shank. The Rock Tamers cover all but about 2"-3" of the bumper, so mounting lights under, or flush mount into, the bumper will be useless when the Rock Tamers are in use.
Any suggestions?
Old Sep 5, 2025 | 01:08 PM
SARDiverDan's Avatar
SARDiverDan
Wouldn’t the camper block whatever light you put back there? Maybe run some auxiliary lights on the camper.
Old Sep 5, 2025 | 01:17 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Would something like this work?
Old Sep 5, 2025 | 02:03 PM
6.2caribou's Avatar
6.2caribou
Maybe i could have worded this better. I primarily want more lighting in the hitch area. The camper is a smaller toy hauler, so I have spot lighting in the rear which helps out when backing up. I stumbled across what appeared to be a high output white bar a week or so ago but neglected to record where...
That's a good looking setup, but it mounts on the hitch shank in the same manner that the Rock Tamers mount up...so they wouldn't work when the camper is being used.
Old Sep 5, 2025 | 02:07 PM
novalovr66's Avatar
novalovr66
While this one is not 60" or just white but its red running and white backup. Not what you were looking for but thought I would post anyways.
https://gorecon.com/products/ford-su...f7d17a12&_ss=c
Old Sep 5, 2025 | 07:28 PM
wmellis42's Avatar
wmellis42
4wd Low
This will be a bit more than what you are looking for, but I had one on my 2018 F150, with the white wired into the backup circuit. A great even white light for backing. The amber warning for you would be a bonus. Used it for 4 years without an issue:
https://strobesnmore.com/products/st...48997715149080
Old Sep 6, 2025 | 10:12 PM
Frank79's Avatar
Frank79
Are these yours? I saw same ones on eBay.
Old Sep 7, 2025 | 01:30 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
No, not mine.
Old Sep 8, 2025 | 08:10 AM
Joe T's Avatar
Joe T
Just run these where the blank plastic dually light mount is. Just cut that instead of the sheetmetal?
You can run them ON instead of strobe and all bright white.
https://www.extremetacticaldynamics....CABEgIwi_D_BwE
https://www.extremetacticaldynamics....SABEgL_E_D_BwE
https://www.extremetacticaldynamics....ce-multi-pack/
Old Sep 8, 2025 | 01:17 PM
RbrtLls's Avatar
RbrtLls
I got the one with brake/turn signals/tail lights/backup lights, but only wired the ground and backup lights. You don't have to wire them all.
Old Sep 11, 2025 | 01:17 PM
Turniipp's Avatar
Turniipp
For those that come across this thread searching for similar, below is a link to an option that uses the existing hitch bar without impeding anything you might use the receiver for:
I have these lights and they are well made but spendy.
BMC Lights
Old Sep 11, 2025 | 02:11 PM
Prezi68's Avatar
Prezi68
Morimoto among a few others have a backup light that is the top part of the license plate frame. might want to take a look at that.
Old Sep 11, 2025 | 03:45 PM
AMXDREAMER's Avatar
AMXDREAMER
It seems like the stock LED backup lights on my 2025 Platinum are nowhere near as bright as the LED ones on my 2017 Platinum. I back into my driveway and use the edge of the concrete as my marker and it's really difficult to see with this truck. I have Torklift camper tie downs so the lights that mount on the hitch don't work for me so I'm looking at different clamps and then wiring a small slim light to that. Granted they won't help when I have my camper, hitch and rock tamer style flaps on there, but they will for the rest of the time. If this is mainly an issue when the camper is on and only for limited times why not mount a lightbar to the camper with a quick connect 12V plug tied to an upfitter switch. The other option would be an LED solar powered light that can be mounted to the back of the camper and just turn it on when backing into a campsite or hooking up the hitch. I have one on my camper and travel trailer that turn on with motion at the door and they work decent. The travel trailer is attached with exterior grade velcro for when I arrive at the site,
antirice
Oct 4, 2021 03:28 PM
climb.on
Aug 18, 2021 11:19 AM
EB5.0
Aug 2, 2021 12:40 PM
Robertpinto333
Nov 18, 2020 07:32 PM
191124x7
Feb 2, 2017 03:30 PM
