Chains
12-06-2003, 05:54 PM
on
Chains
I was wondering...
I know studs in your tires are illegal in Ontario, but... Are snow chains legal or illegal?
12-06-2003, 08:55 PM
AFAIK
They can only be used on roads in mountainous areas with a snow pack.
12-07-2003, 05:50 PM
Anything which damages the road surface is illegal
12-07-2003, 06:50 PM
on
I don't plan on using them everywhere I go... My dad has always kept a set in his van and only used them when the snow was really deep or someone got stuck somewhere. I would never just drive around with chains on the tires if I did not need them.
I work for a company that plows snow in the winter, so when the weather is the worst, that's when I need to get to work the most, so if chains are required to get me to work, I was just wondering if it was ok to use them......
12-12-2003, 05:51 AM
on
Hello.
Check with your local OPP, It might save you a fine!
Steve
01-02-2004, 05:29 PM
on
Basically, as I understand it, in Ontario, is that If the road is paved or concrete than NO SPIKES OR CHAINS as they are outlawed.
Besides, if the roads are that bad, you should stay home and snowmobile anyway.....
88Vmax
Ontario Chapter
09-28-2009 09:12 PM
douglpr42
New Member Introductions
09-07-2008 08:41 PM
93F150/302
Illinois Chapter
03-16-2008 08:59 PM
tony_a
Oil & Lubrication
09-01-2005 10:46 AM
scottie2hottie
Ohio Chapter
11-21-2004 08:05 PM
