Lifter noise.............ugly story. - Ford Truck Enthusiasts Forums
Old 12-06-2003, 04:15 PM
Toaster
Toaster is offline
Toaster is starting off with a positive reputation.
Thumbs down Lifter noise.............ugly story.
I have a 98 F150 with 4.2 (97K miles) that developed a severe case of noisy lifters. Went to Ford where I was told I needed new lifters, so I bought new lifters and just changed all 12.
Started motor and low and behold , still same noise.
I have and had plenty of oil pressure, so I am clueless what the problem could still be.
Any help would be greatly appreciated. Please post here or email me.
Thx, Rob
Old 12-06-2003, 04:24 PM
travlnman
travlnman is offline
travlnman is starting off with a positive reputation.
Hey Rob,
Just a thought, but just 'cause you got pressure to the sending unit, doesn't mean you got pressure at the lifter's. Was it clean inside when you replaced them? If not it could be a blocked oil passage. How about a bent pushrod, bad rocker arm, or just sometimes a bad injector or injectors can make very annoying sound right in the valley area and be hard to pinpont. Worst case it could be piston slap or a wrist pin rattling around, eithr way very bad!!
Old 12-23-2003, 11:22 PM
MJEmerson
MJEmerson is offline
MJEmerson is starting off with a positive reputation.
dont know if its true...cause i am not a mechanic...but i heard that sometimes once the damage is done from the bad lifters its pretty hard to fix em. even with new ones. just somthin i heard once
MRStace84
11-14-2012 09:29 PM
craigl58
01-16-2007 12:49 AM
javi2001
19
06-01-2004 09:34 PM
Toaster
19
12-14-2003 07:53 PM
airstream_peddler
Aerostar
09-09-2003 03:15 AM
Quick Reply: Lifter noise.............ugly story.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
