Sponsored by: Real Truck
Parking Brake Fail
Old May 2, 2025 | 03:21 PM
264WSM's Avatar
264WSM
Parking Brake Fail
I replaced my shoes, drum/rotors, hardware and pedal assy. Even have the measuring tool to set adjustment before I put the drum/rotor back on and I still have no parking brake. There is a good bit of slack in my park brake cable. How do I tighten up the slack to get a parking brake!!
2000 F-350 DRW
Old May 3, 2025 | 05:40 AM
99ManualFlatbedFarmTruck's Avatar
2000 F-350 DRW
I thought on back of drum there is an adjustment key you turn with a screw driver like a drum brake. Hope that helps.
Old May 3, 2025 | 07:35 AM
GreyhoundElm's Avatar
GreyhoundElm
You need to tighten the star adjuster on the back of the wheel. If that doesn't do it the cable is out of place somewhere or something was put back together wrong! Good luck.
Old May 3, 2025 | 11:29 AM
264WSM's Avatar
264WSM
If I adjust the back of the plate any more, it drags and causes a lot of heat.
Old May 3, 2025 | 12:07 PM
Pikachu's Avatar
Pikachu
If it's just a stretched (or possibly incorrect) cable, Google parking brake cable tensioner. But first, check the points where the cable jacket anchors under the truck, making sure they're all in good shape and none have corroded to where the jacket slips through.
mgerdau
13
Aug 20, 2023 12:11 PM
KoreanFord
15
Oct 31, 2021 09:41 PM
bf5113x
Oct 14, 2020 02:31 PM
Flaw
Nov 6, 2008 05:27 PM
Labmutt
Escape & Escape Hybrid
Nov 8, 2004 10:43 PM
