Usage of 4x4
Old Dec 5, 2003 | 11:25 AM
Smitty1019's Avatar
Smitty1019
Question Usage of 4x4
Hello all, I just like to say that this is probably the most useful forum that I have ever stumbled across and the helpful attitude of its members is very, very cool.
Now for the question: I have been reading several of the threads regarding A4WD, 4x4, H & L, etc. and have come across in several posts that it is a bad thing to be driving in 4x4 H or L on dry pavement. I don't do this myself because there is no need for more traction on dry pavement. I am wondering why it is a bad idea to be driving on dry pavement in 4x4? Does it damage the transfer case or just chew through tires and gas?
Thanks,
Smitty
Old Dec 5, 2003 | 01:14 PM
PaulC's Avatar
PaulC
Potentially both. Unless a 4x4 system has some type of clutch between the front and rear axle, selecting 4Hi or 4Lo provides a direct mechanical link between all 4 wheels, forcing the wheels to attempt to rotate together at the same speed. The problem is that there are circumstances in which they can't or shouldn't. For example, if the front tires have more wear than the rear tires, the front tires, being of smaller diameter, will attempt to spin more quickly than the rears. Also, the act of turning causes a difference in the rotational speeds between the tires/wheels on the left side vs. right side. On a slippery road surface in 4Hi or 4Lo, the tries can break traction briefly which will relieve the stress on the driveline, therefore no damage can occur. Not so on a dry surface.
Old Dec 5, 2003 | 03:20 PM
Kingsun's Avatar
Kingsun
Thanks for a great post and very useful info Paul!!! These are the kind of post I print and collect!!
Old Dec 6, 2003 | 10:59 AM
Iceman8984's Avatar
Iceman8984
PaulC ...................... You is da man!
Nicely stated.
Dads 66
Jun 8, 2023 11:17 AM
X1Lightning
Dec 12, 2016 09:01 AM
CO Wapiti
Nov 30, 2016 05:26 PM
regreen61
Nov 8, 2016 06:14 PM
grishfish
1997 - 2003 F150
Nov 16, 2001 05:40 PM
