95 powerstoke overheating.
Old Apr 26, 2025 | 12:31 PM
19otto87.'s Avatar
19otto87.
5th Gear
New to the site. I have a 95 powerstroke with 150k on the motor. Has super duty injectors and hydra tuner. Just got the truck and noticed it pushes coolant past the cap and overfill the overflow. I did a block test and it failed but took about 45 min idling. Coolant looked a little funny (rainbow) but oil looks great. I pulled injector cups and replaced. #7 looked like it could have been leaking. Replaced the radiator, fan clutch, tstat and rad cap. It's better but will still push coolant past in a week back and forth to work, about 120 miles. It will get warm under load then drop back down but seems to do it more with the tuner on. The tuner came with the truck and don't know what tunes it has except for the high idle and some more juice, definitely noticeable. I've just been running it with the tuner off. My question regards the head gaskets. I know it's very rare on the 7.3 but I'm wondering if they are the culprit. The fact it's not intercooled with a tuner and I bought it from a kid. Any info would be helpful. Do plan on intercooling it.
Old Apr 26, 2025 | 01:20 PM
97-psd's Avatar
97-psd
Have you done a leak down test on it?
have you ran it with the cap off? Does it overfill it? How fast?
Old Apr 26, 2025 | 07:55 PM
19otto87.'s Avatar
19otto87.
5th Gear
I have not leakdown tested it. I have a feeling it would be hard to track down if it does it most under boost and load. If I pop the cap it doesn't start pushing out immediately. It can idle all day and never have a problem. No white smoke on start up.
Old Apr 28, 2025 | 09:19 AM
knottyrope's Avatar
knottyrope
Where is the temp you are looking at?
There is 8 gallons and it expands a lot. Rad full when hot will fill the overflow on mine and suck overflow almost dry when cold.
Old Apr 28, 2025 | 10:21 AM
19otto87.'s Avatar
19otto87.
5th Gear
If i fill mine all the way to the top of the radiator it will over fill the overflow. If I leave it about 2 or so inches from the top it will take it while to over fill it. It doesn't ever seem to suck it back in. I just drove about 9 miles. When I got back upper hose is solid but cool and it will just sit there and gurgle into the over flow. Once it cools the overflow has the same amount in it. I wouldn't think 9 miles would be enough to do that unless there is excess pressure in the cooling system. If I have the hydra tuner on it will do it quicker under load. With out the tuner it's never been hotter than 190. With the tuner it's been about 205 to 210 then drops. That with and infrared laser thermo.
Old Apr 28, 2025 | 11:27 AM
z31freakify's Avatar
z31freakify
There's two different T stats for the 94.'97 powerstroke, a long one and a short one.
Here's a copy paste from FTE member strokin'_tatsch
"There is a pipe plug on the driver side of the pump right under the t-stat that you can use for water temp, but you need to make sure that the sending unit does not interfere with the t-stat operation as that plug goes right into the t-stat area of the pump. Which t-stat you need at this point depends on which water pump you actually put in the truck.
1994.5-1995 water pumps used a 203* short stem thermostat.
1996 and up water pumps used a 195* long stem thermostat.
If you put a short stem t-stat in a long stem pump, the bypass disc would not seat against the bypass in the pump, so hot water would have the ability to bypass the radiator and go right back into the engine. I'm not sure if it's even possible to put a long stem t-stat into a short stem pump. I've never actually swapped the thermostats between the two.
Anyways, it is possible to interchange these water pumps, so you might have accidentally installed a late model pump on your truck and installed a short stem t-stat.
Also, keep in mind that the stock gauge in the dash isn't really accurate at telling how hot the coolant really is, so verify your water temps with a gauge like you mentioned in your 2nd post."
Old Apr 28, 2025 | 02:51 PM
19otto87.'s Avatar
19otto87.
5th Gear
Thanks for the reply. It has a long stem thermostat in it. Im not really too concerned with the tempature because I think the only time that really happens is when it's low on coolant from pushing it out. I'm just trying to get ahold on the fact that I can't keep coolant in it for too long. I've looked it on a long distance drive and I'm afraid it would just push it out the whole time. Through the summer I pull horse trailers and camper and don't want to until I get ahold on this. Is the factory metal rad cap suppose to be 16 or 18 psi. I also just started piecing some intercooler parts together.
Old May 5, 2025 | 10:06 PM
19otto87.'s Avatar
19otto87.
5th Gear
Just wanted to do a follow up. Pulled the heads off today and found that the head gasket was blown at cylinder 7 from combustion chamber into the coolent passage. Inspected heads and cylinder walls and don't any cracks and such. Glad to get this thing finally under control. I'm intercooling it while I'm at it. Do you guys have any suggestions for pipes and boots and the spyder assy. Trying to do this as cost effectively as possible. I have a 99 intercooler that I've fabed most of the way in. It just doesn't seem like the SD pipes will be long enough to reach the turbo and intake. I thought about just doing 3 inch exhaust pipe but am concerned about rust forming inside the pipes and getting in the intercooler and intake. Any thoughts would be helpful. Thanks.
Old May 6, 2025 | 09:12 AM
knottyrope's Avatar
knottyrope
99 or e99 spider?
There is a big difference
60@F350
Jun 27, 2022 10:08 AM
eberlestock
6.4L Power Stroke Diesel
Jun 8, 2016 10:42 PM
ballbandit
15
Apr 22, 2009 07:54 PM
tomfrey
Jun 28, 2007 02:26 PM
n6nfg
Jul 7, 2005 01:52 AM
