Cps level low?
Old Apr 25, 2025 | 09:12 PM
Stevenm95's Avatar
Stevenm95
Cps level low?
1997 7.3 315xxx automatic 4x4 e40d. I'm trying to chase down a Idle flucuation issue. Slowly been getting worse as time goes on before it would go up 50 60 rpm every few seconds, now it happens almost all the time. While waiting for a compression tester I decided to use forscan to look at some data everything seems to be okay except cam leve low? Also now out of nowhere even when just accelerating from 50 to 60 not aggressively but I'd say medium I blow black smoke. Only with my hydra set on a tune though so I'm not sure if that's part of the issue. I'm thinking maybe bad orings on injectors? Bad Injectors? Hoping it's not piston rings but I will update when I have the compression tester. I put on a mellings lpop, replaced turbo pedestal o rings installed hpop cross over, replaced IPR with RR, ICP doesn't have oil in plug but thinking about changing that out as well just for good measure. Has a crappy k and n air filter waiting for RR to have the 6637 in stock again. Tomorrow I will be pulling the valve covers off and looking at wiring and seeing if I have oil coming from injectors other than spouts. Also surging while driving.
https://youtu.be/Z-NXRDbczc0?si=L0nxg-EwoL-vmV6m
Idk why video isn't showing up.
Old Apr 26, 2025 | 04:09 PM
Stevenm95's Avatar
Stevenm95
Old Apr 26, 2025 | 04:13 PM
Stevenm95's Avatar
Stevenm95
is this normal output?
Old Apr 28, 2025 | 10:05 AM
knottyrope's Avatar
knottyrope
black smoke can mean low boost, have you check on boost leaks?
Old Apr 28, 2025 | 10:09 AM
knottyrope's Avatar
knottyrope
Put a heavy wire on EBPV to keep it closed, looks like its pressure is varied on EBP
https://www.ford-trucks.com/forums/1...wide-open.html
Old Apr 30, 2025 | 08:17 PM
Stevenm95's Avatar
Stevenm95
I havnt made the tester yet but I believe up pipes are seeping, brand new intake boots from RR. Did a contribution test and back to back is passed.
Old Apr 30, 2025 | 08:18 PM
Stevenm95's Avatar
Stevenm95
ebpv is deleted but the plug is just hanging out in the valley
Old May 1, 2025 | 10:00 AM
knottyrope's Avatar
knottyrope
Wonder if its hydra tuning, Set it to default and run it.
Do you have a leaking LPOP seal? That can introduce air in system making for erratic idle.
Old May 1, 2025 | 10:43 AM
Stevenm95's Avatar
Stevenm95
Wgen i bought the truck it had a edge cs2 on it, I ran it for a bit. Then the cs2 would shut down randomly so, I put it to stock the took it out and drove it stock. Still had the idle issue. I replaced the LPOP with a mellings I made sure both surfaces were clean and new oring came installed. The only oil leak I have is somewhere in the valley or the back of the block. I just replaced turbo pedestal o rings a few months ago so should be those but I'll have to look closer.
Old May 1, 2025 | 10:57 AM
knottyrope's Avatar
knottyrope
does it run better with ICP unplugged?
Old May 1, 2025 | 11:13 AM
Stevenm95's Avatar
Stevenm95
nope runs the same and the ipr has been replaced.
Old May 1, 2025 | 11:29 AM
knottyrope's Avatar
knottyrope
Have you tried running 2 qts of ATF in the tank?
That cleared up a lot of my idle after running a tank through
Old May 1, 2025 | 11:44 AM
Stevenm95's Avatar
Stevenm95
i was doing that but read that it was bad for the injectors due to due detergents, was going to do more research. I also use hotshot stiction eliminator in every oil change.
Old May 1, 2025 | 01:07 PM
knottyrope's Avatar
knottyrope
HEUI dont have stiction issues like the 6.0 does
https://www.ford-trucks.com/forums/1...ion-fixed.html
Old May 4, 2025 | 07:58 PM
Stevenm95's Avatar
Stevenm95
well I just put some atf in so we will see what happens.
KrisNel_92
Feb 28, 2026 12:11 PM
pinbill
25
Sep 5, 2023 08:46 PM
yzf450motoxrider
20
Apr 28, 2019 05:09 AM
JonathanN
13
Jan 19, 2012 08:52 PM
PowerstrokeJunkie
36
Sep 17, 2008 10:16 PM
