MAP sensor connector problems.
Old Apr 22, 2025 | 06:06 PM
Wiill's Avatar
Wiill
4wd Low
I kept reading these forums without creating an account to see if I could figure out what was wrong but doing so hasn’t given me any answers. My truck will not run for long when the MAP sensor (Electrical connection) is plugged in. It will start up sputter and then die. When I unplug it though, it runs fine but rough like you’d expect it to because of the unregulated air pressure. When I plug the electrical connection back in the truck immediately dies. I’m getting proper voltage to my MAP sensor. I’ve replaced my map sensor, and have gotten the same results. Any thoughts on what might be causing this?
For reference this is a 1993 F-250 with a 5.8l 351w and 199k original miles.
Old Apr 22, 2025 | 07:37 PM
Conanski's Avatar
Conanski
Can you pull codes? If you don't get any response the PCM itself is suspect.
Old Apr 22, 2025 | 07:56 PM
Wiill's Avatar
Wiill
4wd Low
No. I cannot. I followed a YouTube tutorial on how to get my check engine (pre-OBDII) light to give codes. I put a paper clip in the certain ports on the EEC test and the other gray connector to give the engine codes to the check engine light but the check engine light doesn’t flash. Also I don’t know if I have a PCM or ECM. All I know is that whenever I try to do a KOEO test the engine light doesn’t flash. The same goes for a KOER test as well.
Old Apr 22, 2025 | 09:24 PM
Conanski's Avatar
Conanski
OK. that also suggests a PCM problem. Question, does the CE light come on when the key is first turned to run before the engine is started? If it does then you know the bulb isn't burned out or missing.
PCM and ECM are two names for slightly different computer controllers, the former controls both engine and trans while the latter is just for the engine when a manual transmission is used. They look identical
Old Apr 22, 2025 | 09:56 PM
Wiill's Avatar
Wiill
4wd Low
Yes, the CE light works. I know the computer is at least trying to give me codes because when I go to start it, it comes on then goes off in a split second when the paper clip connector is in but does not go through the series of flashes to give me the codes. It just stays off. Also if what you said is the case then I have a PCM because my truck is an automatic.
Old May 2, 2025 | 10:04 PM
Wiill's Avatar
Wiill
4wd Low
New PCM in FT2F-12A650-PB which matches my old one. Truck is sluggish as crap in the throttle and won’t move on a slight incline. The breaks feel as if the truck was off. I think I need to program my PCM to my VIN but that might be the problem. Also it idles low as crap. I was able to pull a 327 code which I fixed and then I couldn’t pull anymore because my fuel pump relay blew and the fuel pump doesn’t turn off. That’s where it’s at since I last posted on this thread.
Old May 2, 2025 | 11:58 PM
Conanski's Avatar
Conanski
That isn't necessary, that level of integration with vehicle components wasn't a thing back when this EFI system was designed, any PCM will work in any vehicle as long as it has the correct hardware and software for the vehicles powertrain.
That is a classic sign of a failing PCM, where did you get it?
It easy to test the relay, just remove it from the truck and momentarally apply 12v to the coil pins, if it clicks it's OK. If the relay is good I'd suggest sending the PCM back as faulty and requesting another.
Old May 3, 2025 | 08:33 AM
Wiill's Avatar
Wiill
4wd Low
Ok I will do that. Thank you.
Old May 3, 2025 | 12:39 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Only if the transmission has overdrive. Since you have a 3/4T truck that limits which transmission you have to either the mechanical 3 speed (C6) or the Electronic 4speed Overdrive (E4OD).
Old May 4, 2025 | 09:05 PM
Wiill's Avatar
Wiill
4wd Low
My truck has the E40D with the overdrive. But ever since I put the new PCM in it’s had some sort of pressure or vacuum issue that’s causing my brakes not to function unless they’re in reverse, and my transmission not to shift and my engine not to rev under load unless it’s in reverse, and my fuel pump not to cut off either. And it only cranks off starting fluid but when it’s hot it cranks fine. The other thing I noticed is that whenever my hood is closed it idles low and when opened idles up. So just a bunch of weird stuff.
Old May 4, 2025 | 09:58 PM
My4Fordtrucks
Seems like you got a bad reman computer.
Old May 5, 2025 | 09:35 AM
wwhite's Avatar
wwhite
Wow. Not sure what to say with all that.
Your last sentence suggests that the hood is closing of the air inlet tube, which would choke the engine.
Mountain_anderson
Oct 7, 2023 05:15 PM
Steve237
Dec 26, 2022 06:46 PM
tooldforthis
3.0L Powerstroke Diesel
Nov 8, 2020 01:35 PM
brichert
May 26, 2017 06:46 AM
Talyn
17
Jun 19, 2011 02:06 PM
