Just puting the truck back together from a frame off resto.. And some motor upgrades, new injector cups and re sealed injectors..
While cranking to fill hpop res and heads with oil, bleeding air etc, I can not get more then 200 psi out of the HPOP system.. Motor was running strong when shut down for re & re.. so im not convinced the hpop or the ipr all of a sudden went bad.
???? with KOEO should there be a voltage across the two pins on the ipr pigtail????
I have nothing... all fuses are good, wait to start light does its thing... but there is a weird buzzing sound coming from under the dash... Never heard that befor...
Im kinda wondering if the OEM anti theft moduel is causing this.. ...
