Upfitter wires
Old Apr 6, 2025 | 09:27 PM
mhodgson's Avatar
mhodgson
Upfitter wires
Drivers side under the hood up near the firewall are four wires stubbed out, red, black, white, blue…12-24 gauge. Same wires are under the dash taped to the bottom of the steering column. Inside however, there are two smaller wires with heat shrink tubing on the ends in the same bundle, anyone have any ideas on what those are? 2005 Ex V10 EB 4x4.
Thanks
Mike
Old Apr 7, 2025 | 04:50 AM
01__Excursion's Avatar
01__Excursion
Sounds like the customer access wires, allowing you to add accessories with wires already passed through the firewall.
Old Apr 7, 2025 | 07:26 AM
mhodgson's Avatar
mhodgson
Yeah, the four wires I mentioned are definitely that (I call them upfitter wires) and indeed all four wires appear on both sides of the firewall. These other two wires are taped into the same bundle but do not appear on the engine bay side.
Mike
Old Apr 7, 2025 | 07:53 AM
mhodgson's Avatar
mhodgson
Guess it would have helped if I watched the video!! I will go and look at the wiring diagram. I have two extra but it would be great if they were both tied to the fuse block!
Thanks again,
Mike
Old Apr 7, 2025 | 04:19 PM
01__Excursion
Possibly tow control? But I think there are more than 2 needed.
Old Apr 7, 2025 | 10:21 PM
INFRNL's Avatar
INFRNL
They should be customer access wires. you should find the other end near the PCM on the inside, they are taped to the wiring harness near there. They are worthless IMO...nobody wants to tap onto wires twice when they should have a solid run besides fusing.
Old Apr 8, 2025 | 04:57 AM
01__Excursion
He mentioned 2 sets of wires, one set is verified as the access wires, the other is unknown.
Old Apr 8, 2025 | 11:33 PM
BigGreenEx's Avatar
BigGreenEx
Isn’t that where the high idle wire is located? It’s possible that’s what your seeing, not sure if high idle is one or two wires.
OX2
Oct 15, 2023 02:53 PM
GBOCanada
May 30, 2022 04:51 PM
Quality Equip Design
Jun 4, 2010 06:25 PM
XxfirmanxX
Electrical Systems/Wiring
Dec 5, 2004 07:39 AM
Tckhan
Jul 22, 2004 03:21 PM
