Confused E4OD after replaced speed sensor???
Old Apr 1, 2025 | 07:16 PM
matt73403's Avatar
matt73403
3rd Gear
1997 F250 E4OD 4wd —
Had regular speed sensor issues and replaced the speed sensor in the rear differential. But nothing changed.
starts driving normally but at 20mph speedo drops to 0 and starts bouncing all over, tranny gets confused and it’s like I’m in neutral.
If i select 1st or 2nd on column it’s normal.
Overdrive light on shifter handle is not blinking. works as normal.
CEL and code for VSS but i just replaced it.
Is this a transmission issue? any advice helps.
Thanks
Old Apr 1, 2025 | 09:18 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The VSS code doesn't always mean the VSS is bad. It can also be caused by a bad wire to the VSS, a bad PSOM (Programmable Speedo-Odo Module,) or something damaged inside the differential. My money is on the PSOM to win, the wiring to place, and the diff problem a distant show.
Old Apr 6, 2025 | 09:39 AM
96XLTczny's Avatar
96XLTczny
If you've never done SMT(surface mount tech) soldering before, better to leave it to outfits like clusterfix.net or autotechrescue.com
Too easy to overheat a circuit board causing a trace to lift.
LittleBlue95
Nov 9, 2023 01:51 PM
chris1996
Oct 10, 2016 09:28 PM
Cdy1
Oct 20, 2008 07:12 AM
Jarrett T
Nov 23, 2004 12:20 AM
