Aerostar Ford Aerostar
Loose Wiring harness?
Old Feb 28, 2025 | 12:51 PM
Cearrson's Avatar
Cearrson
7th Gear
Thoughts on this? It recently began happening, I've taken off panels to access more wiring harnesses to see if I could find a loose one to no avail. I've also gone around and oiled up all the door closures etc. They all seem to close well, and dome light isn't coming on while driving, just the door ajar light going wacky.
Old Feb 28, 2025 | 03:40 PM
Truckwardo's Avatar
Truckwardo
I like to replace the contact switches since they get rusty. Have you looked at those?
Old Mar 1, 2025 | 11:50 AM
xlt4wd90's Avatar
xlt4wd90
The earlier Aerostars with the rectangular instrument panel had an illustration in one of its displays that would show which door was ajar. I guess the newer models with the contoured dash don't have that anymore.
If its one of the front doors or the rear hatch doing this, check to see if the plastic bushing on the striker post is gone, preventing full closure of these doors. It's hard to find an exact replacement for those from the "HELP" packets at your local auto parts store, but you can try.
If it's the sliding door that the light is complaining about, you can try cleaning the contacts on the edge of the door and the B-pillar that it slides into. If that doesn't work, the sliding door may need to be adjusted to close more tightly.
Old Mar 1, 2025 | 05:51 PM
Cearrson's Avatar
Cearrson
7th Gear
After these comments and closer examination its definitely the sliding door contacts, they are quite worn, are they replaceable? I will maybe add some photos soon
ThA CoPyCaT©
Aug 21, 2022 09:07 AM
DanteV
Electrical Systems/Wiring
May 17, 2022 10:57 PM
salamber
Oct 11, 2020 06:45 AM
48prerunner
WTB - Parts & other
Nov 14, 2016 03:06 PM
