Coolant temp will not read
Old Feb 28, 2025 | 12:11 PM
LocalOBS's Avatar
LocalOBS
3rd Gear
Hi, keeping it short, I will watch the coolant gauge in my truck rise until it gets to about 1/2 to 3/4 of what it should run at, but then the gauge says the coolant temp drops right back down to just above the operating temp, I've felt my coolant lines when it does that and they are still hot so it's an electrical/sensor issue, but im not sure where to start
Truck: 92' f150 351w
Old Feb 28, 2025 | 12:14 PM
Jim_K's Avatar
Jim_K
Most likely its not electrical, but rather you have air in the system. That upper hose on the 351 sits higher than the top of the radiator, and it's a stone cold bee-yotch to bleed sometimes.
Old Mar 1, 2025 | 04:05 AM
manicmechanic007's Avatar
manicmechanic007
You are seeing "normal" thermostat operation?
When that thermostat opens and lets cool coolant into the engine, the temp gauge goes cold
The hose gets hot due to the thermostat just let hot coolant into the radiator
You can watch that happen a couple of times as the engine gets to normal operating temp
Old Mar 1, 2025 | 06:58 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by LocalOBS
coolant gauge in my truck rise until it gets to about 1/2 to 3/4 of what it should run at, but then the gauge says the coolant temp drops right back down to just above the operating temp…
What does this mean? Where on the gauge do you think operating temp should be?
97audia4
25
May 24, 2022 09:45 AM
tmathers03
2015 - 2020 F150
17
Feb 3, 2019 10:32 AM
corksil
Aug 8, 2015 01:25 PM
IMASAP
Jun 25, 2015 09:59 PM
Ken_C
Feb 11, 2013 08:01 AM
