2023 7.3 Starting issues
Old Feb 11, 2025 | 07:54 PM
2373Godzilla's Avatar
2373Godzilla
3rd Gear
I have a '23 7.3L F-250 with less than 20,000 miles and not even a year and a half old. This is the second time it has happened to me, but when starting pickup only accessory power comes on, and won't even try to start. I've tried putting it in gear and back in park, then starting with the remote, 2 fobs, and on the app and get nothing. Let it sit for half a day and it starts right up. I called Ford both times and they said they had no idea why it was doing that. Thought I'd see if anyone else has had these issues as well.
Old Feb 11, 2025 | 09:39 PM
willynilly's Avatar
willynilly
considering the long history of crap batteries on these trucks thats the very first place i would start my investigation
Old Feb 11, 2025 | 09:46 PM
2373Godzilla
3rd Gear
I was thinking that, but didn't try charging them this time and it started right up a day later with colder (subzero) weather.
Old Feb 12, 2025 | 02:27 AM
willynilly's Avatar
willynilly
i see no reason to bother charging them. check no load resting voltage. look fot corrosion at the posts and surrounding area as many of them have leaked. verify alternator output although there should be a dash light if its not in the specifies range but thats why you verify. this is the simple first things i personally would do
Old Feb 13, 2025 | 11:24 AM
Ford Motor Company's Avatar
Ford Motor Company
Official Ford Pro Rep
Hi there! Please send us a private message with your VIN so that we can take a look into this.
Old Feb 13, 2025 | 12:55 PM
2373Godzilla
3rd Gear
I tried sending a message but says I am not authorized to do so.
Old Feb 20, 2025 | 01:40 PM
Split rims's Avatar
Split rims
I believe that you need ten posts to PM.
Old Feb 20, 2025 | 05:45 PM
ejkTN's Avatar
ejkTN
Try jumping it with a 2nd vehicle. Test the starter right before you connect then again after. If it suddenly wants to start then it's the battery or its terminals. My friend with a Honda Pilot had a failing battery. Would randomly fail to trigger starter then work fine a few hours later. Did a free battery test at Autozone which said their battery was failing, fixed ever since by their new battery.
Old Feb 21, 2025 | 01:22 PM
TestPilot57's Avatar
TestPilot57
Probably a totally unrelated incident, but.
I had a 2020 Ram pickup and every once in a while it wouldn't try to start (i.e. engage the starter).
In total it happened maybe 10-12 times.
20% of the time my L-Ion jump pack would start it.
80% of the time it would start when jumped from another vehicle
(never simply would not start)
Battery was load tested good, all connections good.
Dealer finally replaced the starter. Never a problem since (at least 3 years).
Old Feb 21, 2025 | 03:08 PM
SeriousDuty's Avatar
SeriousDuty
Trailering
OP, did you get numerous warnings on the driver display when you tried to start? That happened to me after this last cold spell in Minnesota. My lithium jump pack had no effect. I let it sit for an hour and it started right up. The dealer service dept put the battery on their load tester and it tested failed, even though my voltmeter read 12.4 volts. He said they would warranty the battery since my truck is also a mid '23 build.
visiongrill
Jan 27, 2024 06:20 AM
matconger
Jun 22, 2010 09:28 AM
mantecans
May 8, 2010 07:32 PM
cbstruck
Jul 11, 2003 11:17 AM
