CP4
Old Feb 9, 2025 | 09:20 PM
SICA526's Avatar
SICA526
Originally Posted by Rwhjr
it’s not magic, the concept of the S&S kit is really simple.
I’ll take your last post (containing no examples) as admitting you don’t have an example of the current DPK from S&S as not being effective.
That's a fallacy .I don't let FEAR run my life.Some people do.FEAR SELLS,you're the proof
Old Feb 9, 2025 | 09:23 PM
Rwhjr's Avatar
Rwhjr
Oh lord…..this isn’t as deep & philosophical as you’re making it out to be.
i understand the concept of the S&S kit and it has a clear, simple benefit.
no need to pretend like this is some do or die situation but if you want to refrain from posting until you have any example of what you’re speaking about I’ll patiently wait lmao
Old Feb 9, 2025 | 09:28 PM
SICA526's Avatar
SICA526
no need to pretend like this is some do or die situation but if you want to refrain from posting until you have example of what you’re speaking about I’ll patiently wait lmao
Its ok on my end.I didn't fall for the fear tactics,YOU DID....The only video of this snake oil is made by the Manufacturer .Show me 3rd party video of the testing..That should not be hard if it is such a GREAT product.Should it?I'm not losing any sleep tonight over this.That is for sure>>>>
Old Feb 10, 2025 | 06:28 AM
IADiver's Avatar
IADiver
So anyway, have there been many failures? I haven't hear of many except for owner induced.
Old Feb 10, 2025 | 06:45 AM
speakerfritz's Avatar
speakerfritz
after 10 years of blaming customer behavior as the cuase of CP4 failures...ford started to use CP4's that have pinned cups.....I think the change started 2020. pinned cups prevent the cp4 pistons from rotating and if rotated the bearings at the base of the cup dont spin any more...they just start to wear until failure.
since 2020 there have been cp4 failures and those failures put into question how effective pinning the cups really was....until ford admitted to the stale fuel problem during the covid era which resulted in cup cups being jammed with diesel tar from stale fuel because the geniuses at ford didnt use any fuel storage additive's in the trucks fuel knowing the trucks were going to sit.
now when they finally got around to starting them...the CP4 timing gear slipped since the timing gears is a press fit and some slipped to the point that the CP4's later failed...others slipped only to the point of loosing optimal fuel pump timing...so they changed the code to match the mechanical mis aligned timing gears. publicly they are saying the code change is to make the cp4's run cooler...this is by changing the metering valve threshold so that more fuel goes to the cp4 and the more fuel would be mostly unused and would basically return back to the tank carrying heat.
and oh by the way...when you put in a 2nd gen CP4 DPK you create a dedicated fuel path which sends dedicated fuel across the CP4 bearings and this fuel never goes directly to the injectors but instead always goes back to the tank carrying heat with it.
so definitely FORD...if CP4 fails are due to customer behavior...why has ford pinned the cp4 cups so they dont rotate and why is there a code change with the end goal of cooling off the cp4 bearings.
Old Feb 10, 2025 | 08:14 AM
powerboatr's Avatar
powerboatr
this has to be the best, straight forward reply and some good to know on the cp4
Thank you
Old Feb 10, 2025 | 10:38 AM
acdii's Avatar
acdii
I stand by using good fuel and a good additive to protect the pump and a DPK to protect the HP side just in case the pump does fail. I wish I could buy lifetime insurance for $400 for the rest of the truck.
Old Feb 10, 2025 | 12:18 PM
jcb804's Avatar
jcb804
Its just an inferior design. Out of the three powerstroke trucks ive had, two had a failed cp4 pump. I purchased all three trucks the same day and they were all filled from the same on road diesel tank I had at the shop. The two that failed were in F250 foreman/personal trucks that the operators chose to also use lube additives.
The one that didn't fail, and I still have in service with over 200k has never seen an additive and since 2021 gets filled up at whatever local fuel station with whatever quality diesel they have because I stopped filling my on site tank.
Supposedly the cp4 is also used in many other applications but as far as I know none of my 10+ pieces of diesel powered equipment has one. Never had trouble with premature hpfp failure on any other of my diesels and they all get used to very high hours/mileage with no additives or special treatment.
Old Feb 10, 2025 | 12:24 PM
speakerfritz
There are different additives ( anti gel, ctane boost, cleaners, biocide, water emulsifier or water deemulsifier, etc) sone additives break down diesel lube value unless they are specific lube additives.
Old Feb 10, 2025 | 12:32 PM
SICA526's Avatar
SICA526
I would like to know which additives Break down the lube value of pump diesel,so I can stay away from those.Please let us know
Old Feb 10, 2025 | 12:45 PM
speakerfritz
simple google search will get you lots of info....the discussion at the below link refers to a third part study...note the ones that indicate "worse than untreated diesel" or something to that effect.
but yes...all diesel additives are not all lube additives
https://bobistheoilguy.com/forums/th...esults.125503/
Old Feb 10, 2025 | 01:45 PM
SICA526's Avatar
SICA526
15 year old study.Thanks
Old Feb 10, 2025 | 05:07 PM
  #28
speakerfritz
Originally Posted by IADiver
Have we heard of any CP4 failures in 23+ trucks? There must be a few getting some miles on them now.
https://www.ford-trucks.com/forums/1...s-ford-cx.html
Old Feb 10, 2025 | 06:10 PM
  #29
OX2's Avatar
OX2
What was the final outcome. Last activity of OP was Jan 4.
Old Feb 13, 2025 | 05:35 AM
  #30
jcb804's Avatar
jcb804
Opti-Lube bottles were what littered my shop shelves and floors of those two trucks when they were active in my fleet. Said extreme lubrication in big enough letters on it. I take it that was a lubricant enhancer. I never bought the stuff for the company, the two guys who wanted those trucks bought that stuff out of pocket.
