Aerostar Ford Aerostar
Frontend alinement
Old Jan 1, 2025 | 09:39 PM
bertha66's Avatar
bertha66
Frontend alinement
Took out 1990 Aerostar in for an alinement after installing upper "A" frame bushings. Shop could not get the camber set on the right side. After working on it for 2 hours he gave up. The recommended repair was a new set on front of coil springs, thought is that new springs will straighten up the wheels. Any thoughts on this? Van has 400K on it and the springs have not been changed,
Old Jan 1, 2025 | 10:00 PM
xlt4wd90's Avatar
xlt4wd90
I'm guessing you removed the upper A frame brackets when you replaced their bushings. Most manuals tell you to mark where the brackets were before you start taking them apart so you can return them to the same positions when you re-install them. The problem is there is a plate between them and the frame rail, and you need to mark them both, as they both shift around.
If the shop could not set the camber, you need to loosen the 3 giant bolts that old the brackets (and subframe) to the frame rails and shift the brackets. If there is too much positive camber, you need to push them in a little. If it's too much negative, pull them out a little. This time, mark the positions of the brackets and plate before you start so you have reference to check how much you've shifted them.
Old Jan 2, 2025 | 07:49 PM
bertha66's Avatar
bertha66
I did mark the plates and measured with a Didital calipers to reset them. As the right side was done last summer, I did not change anything on that side, only the left. That being said,, the left side was good, it was the right side that they could not get the Caster setting into spec. Thank for the response!
Old Jan 16, 2025 | 09:13 PM
bertha66's Avatar
bertha66
I did take the Aerostar back and showed the kid how to move the upper "A" frame, I had assumed he knew that the a arm would move, I was wrong. When I asked him if he had tried to it, he said that the computer did not say it could move, So I showed him where the bolts were and how to move it, Got the alignment down in 40 mins... and then thanked me for the information. To old van is 10 years older than the tech working on it.
Old Jan 17, 2025 | 12:54 PM
xlt4wd90's Avatar
xlt4wd90
Great! Teaching a new dog some old tricks.
Great Work
Apr 26, 2021 10:22 PM
annaleigh
Mar 20, 2017 04:59 AM
Geoph1986
May 5, 2012 10:29 PM
Sean709
1978 - 1996 Big Bronco
Dec 13, 2006 06:57 PM
rfgree
Jan 8, 2003 05:39 PM
