Service charging system soon message
Old Nov 29, 2024 | 04:56 PM
jcreacy22's Avatar
jcreacy22
1st Gear
This light is making me crazy. Battery voltage at 14.8 when running, message keeps appearing sometimes with the battery light. 6.7 HO 55k miles dual alternators. Top alternator appears new. Batteries both test good, my ICON T8 says generator 2 is making almost 28 volts. Any ideas would be appreciated.
Old Dec 1, 2024 | 03:36 PM
SICA526's Avatar
SICA526
Have a reputable shop diagnose the issue
Old Dec 2, 2024 | 10:24 AM
seijirou's Avatar
seijirou
The voltage is too high, voltage regulator problem. SICA526 is right, if you're not sure what to do then take it to a shop. If you continue running with voltage too high it will damage the batteries as well, and other far more expensive components if it worsens.
Old Dec 2, 2024 | 01:21 PM
acdii's Avatar
acdii
I think the second gen is supposed to make 28 volts for the Rapid Heater. If you are seeing 14.4-14.8 at the batteries, then the 28V you see on the other alternator is for a separate system. If it were tied to the batteries you would have voltages all over the place. I don't remember where I saw it, but it requires both batteries and the alternator to power it and its 1400 watts. Has a 125amp fuse too. 14+14=28, so maybe?
It might be normal, but I can't find docs to back up what I heard.
Old Dec 2, 2024 | 01:35 PM
Neohio's Avatar
Neohio
www.DieselCurrent.com
28 volts may charge the Pro-power onboard batteries?
I want to say I read something about 24v batteries for that system.
Old Dec 3, 2024 | 10:16 AM
acdii's Avatar
acdii
Maybe this is what I heard that used the second alternator at 28 volts.
ed77
Modular V8 (4.6L, 5.4L)
20
Sep 3, 2020 11:15 AM
KHflatbed
May 31, 2017 10:18 AM
andym
May 19, 2015 07:37 PM
kyle brauner
May 16, 2011 11:12 PM
dumdum9599
Dec 18, 2006 02:47 PM
