washer pump no flow
Old Nov 23, 2024 | 11:23 AM
ehusmann's Avatar
ehusmann
washer pump no flow
1993 F150 5.0L: Cannot get washer fluid on the windshield. Jump the washer pump to the battery and you get good fluid flow to the glass. So the pump works and hoses and nozzles are clear. Tested voltage at pump plug and got 11.4 volts. Wipers seem to work well at all speeds. Thoughts please.
Old Nov 23, 2024 | 02:29 PM
Soup bean's Avatar
Soup bean
I would suspect the washer switch.
Is your washer switch in the multi function switch, on the steering column stalk, or on the dash?
Second suspect would be ground connection, especially if you provided a battery ground when you tested the pump.
The washer pump ground might be (EDIT): Is... right near the reservoir, on the upper driver's side corner of the radiator support.
Old Nov 23, 2024 | 02:36 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Get a 12V test light and connect it to the washer pump plug. With the key on, push the washer switch. Is there power at the connector? No? Go to the multifunction switch. Is there power out of the switch when pushing the switch?
Old Nov 23, 2024 | 06:04 PM
ehusmann's Avatar
ehusmann
Soup Bone: Yes, multi function switch.on column stalk. Will check grounds tomorrow.
My4: Did use a test light at the pump plug. Had power when switch was pushed.
Thank. Will let you know results.
Old Nov 23, 2024 | 07:04 PM
My4Fordtrucks
How did you apply power from the battery? Did you disconnect the plug and run both power and ground back to the battery or ran power to the positive side of the connector with it still plugged into the pump?
Old Nov 23, 2024 | 07:23 PM
ehusmann's Avatar
ehusmann
Unplugged from pump. Then wires from battery to plug.
Old Nov 23, 2024 | 07:37 PM
My4Fordtrucks
From your description it sounds like a ground problem or the connection itself.
Old Nov 23, 2024 | 08:09 PM
Soup bean's Avatar
Soup bean
Sounding more like a connector issue.
Old Nov 24, 2024 | 06:32 AM
mackendw's Avatar
mackendw
I had the same issue on my 87 f150...it was corroded connectors at the plug that goes to the washer pump.
Old Nov 24, 2024 | 01:26 PM
ehusmann's Avatar
ehusmann
Found corrosion on the ground wires. Cleaned and the washer water flowed. At least until the right nozzle plugged. Thanks all.
Old Nov 24, 2024 | 02:08 PM
Soup bean's Avatar
Soup bean
Glad you got it.
1966f250
Aug 11, 2024 07:29 PM
MYTRUCKNOWRATTLES
Mar 16, 2023 05:55 PM
ThreeHundredSix
Dec 4, 2018 06:55 PM
fmr9
Nov 20, 2007 12:30 AM
Desertwolf
Jul 20, 2007 12:47 PM
