Edge Evolution Programmer (old style)
Old Oct 4, 2024 | 04:59 PM
strokie's Avatar
strokie
1999-2003 Ford F-Series 7.3L Power Stroke
https://documents.edgeproducts.com/15001.pdf
is this device any good? its installed on a 7.3 Im looking to buy. or should I replace it with a PHP hydra or similar?
maybe I can use it as an argument to get a better price on the truck even?
Old Oct 4, 2024 | 08:24 PM
John in OkieLand's Avatar
John in OkieLand
never saw one myself, I have the Hydra which is an awesome tuner.
Old Oct 4, 2024 | 08:25 PM
strokie's Avatar
strokie
its quite old, and also not very common..
Old Oct 4, 2024 | 08:37 PM
BWST's Avatar
BWST
Got Data?
I had that one on my first 7.3. It's a pretty basic power adder - I felt it did not add much in the towing range, and I don't think it affected shifts, but it did let you keep an eye on EGT which was good.
Recommend removing it, get the truck running 100% in its stock configuration, then consider the hydra and a dedicated set of gauges for EGT and Fuel pressure at minimum.
Old Oct 4, 2024 | 09:19 PM
John in OkieLand
IF,
you go the Hydra tuner,
the Edge Diesel Street kit is not much difference in cost that good EGT, Coolant Temp, and Fuel Pressure gauges....
that is the route that I chose.
You get everything in one small package...
the CTS-3 has 3 screens, each of which is complete programmable to your wishes.
as of today, my main screen is like this, once I get the EGT probe thru the firewall, it will change again.
The Edge CTS-3 has a lot of bonus features.
It can do Diagnostics and display the error Codes, and it can clear all DTC codes.
lot of benefits to the CTS-3
Old Oct 5, 2024 | 09:35 AM
RacinJasonWV's Avatar
RacinJasonWV
Originally Posted by John in OkieLand
the Hydra has 3 screens, each of which is complete programmable to your wishes.
John meant CTS-3 here. The Hydra has a simple controller for switching tunes.
I think you can use the old Edge as just a display. This could give you the gauges while you do other mods (ie Hydra)and save some money. Eventually you’ll probably want to upgrade to something like the CTS for gauges though.
Old Oct 5, 2024 | 10:25 AM
John in OkieLand
I went back and edited that post, and yes, DA that I am today, I must be cross eyed..
it is the CTS-3...
the nice little Hydra just has a tiny little box with 2 buttons and a 2 digit display....
I leave it on 80hp DD mode.
fatcowvtx
Oct 24, 2010 11:24 AM
strokingbeast
Dec 27, 2009 09:14 PM
