Shock replacement
Old Sep 21, 2024 | 08:46 PM
dfixit1's Avatar
dfixit1
Shock replacement
I have a 95 f150 5.0 XLT/Eddy Bauer Edition
after hauling a Full load of wood I found some broken wires located in the frame. After a a good hard look over it seems the drivers side top shock bracket had bounced off the wiring loom even as that sits on the bottom of the frame. I finally found the issue and seems the top shock bracket bottomed out and clipped the loom. Could be I was way over loaded in combonation with 30 year old shocks. I don't normally over load to that extreame but thinking about new shocks anyway. Any input on a good quality shock set in the rear for starters. I'd say meidum duty +, and I'll try to linit my 1/2 ton truck to less than 1k lbs load
Old Sep 21, 2024 | 10:16 PM
samuel4wolfpack's Avatar
samuel4wolfpack
When I had my 1991 F250 LD 4x2 with the M5OD and the 302/5.0 engine, I put in KYB Gas-A-Just monotube shocks (front and rear ends of the truck). The truck felt better after putting in all four (4) shocks.
Before installing each new shock, I had to compress each shock and manually tie it with wire around the compressed length before putting it into position.
fastfarmer
Large Truck
May 8, 2024 07:40 PM
Pappys53
Sep 2, 2011 09:11 AM
SmashFascism
Feb 26, 2008 04:18 PM
460
27
Jul 19, 2006 06:47 PM
geolguy
1997 - 2003 F150
Jul 28, 2005 05:25 AM
