Lift info
Old Sep 15, 2024 | 07:07 AM
Edgethis's Avatar
Edgethis
Looking closer, seems like you have stock style obs lift springs, not an rsk.
That front crossbar with the hitch looks welded to the frame.
Can you see any marking or labels on the leaf springs?
Old Sep 15, 2024 | 11:37 AM
Jae96–7.3l's Avatar
Jae96–7.3l
Trailering
that hitch is tack welded. No clue what I was used for but I plan to remove it. Can’t see any labels on the leaf springs. So would it be as simple as just replacing them and the pitman arm to get it back to stock?
Old Sep 15, 2024 | 12:04 PM
tjc transport's Avatar
tjc transport
i ain't rite
sorta. you will need stock springs, stock pivot drop bracket, and stock pitman arm to bring front back to stock.
for rear, either remove the lift blocks between axle and spring and shorter stock u-bolts, or if no blocks new stock springs and spring u bolts.
Old Sep 15, 2024 | 01:32 PM
Edgethis's Avatar
Edgethis
As mentioned, the leaf springs, pitman arm, and trac bar bracket would need swapped for a stock setup.
Probably wouldn't be hard to fond someone wanting to trade their stock stuff for yours.
Eric Carroll
Jun 12, 2004 10:58 PM
