How many miles do you guys have on your trucks ?
#4712
2012 6.7
I have a 2012 6.7 all original. Only thing was done was replaced radiator and done a egr delete. Truck is clean no rust and still running strong at 546k. I keep getting told by all mechanics who look at my truck that they never seen anything with this many miles and be so clean. So hopefully I can pull another 500k off of this motor
#4715
I've got a 2000 F-250 with 187,000 miles on it. The guy who owned it before me was near brain-dead on maintenance though... virtually everything he did was done wrong (noting that I bought it at 100k miles). Mine's got the 5.4L Triton, and 5-speed manual Z5 tranny. What I fixed so far:
Brian
- Rear end rebuild at 110k miles ($1100). Previous owner had a leak and never fixed it, ran it dry, "fixed" it in his own garage and didn't get the pinion bearings in correctly ... they wore quickly and whined like crazy after I got it, hence the professional rebuild
- Partial transmission rebuild at 150k miles ($1900). Previous owner had motor oil in it. Motor oil is toooo slick compared to the ATF that this transmission requires (yes, automatic transmission fluid - the manual requires it). The slick motor oil prevents synchros from working as they should, and the guy'd been jamming gears to get it to shift ... end play in the 5th gear synchro was out of spec and grinding when shifting into 5th. Rebuild include new bearings (didn't need them), synchros (only 5th needed one), and otherwise the transmission was like brand new inside. It's got the proper ATF in it now and works great.
- Clutch, clutch master and slave, pilot bearing, throw-out bearing, flywheel turned, and pressure plate replaced at 150k miles (when tranny was rebuilt) ($300). Previous owner had replaced the clutch, but left the original pressure plate and throw-out bearing in place. The pressure plate had bad wear and should've been replaced. I buy into the the "If you're going to drop the tranny ... do it once instead of twice ... replace all clutch related stuff while the thing is off the truck ... cheaper that way" philosophy.
- One tie rod replacement, front end alignment and adjustment of the steering gear play. The guy had the steering gear adjustment all the way out and super sloppy. Drives like new now.
- Leaking power steering pump. Replaced pump.
Brian
#4722
#4725
- New 5th gear (was grinding), syncros in tranny. <-Caused by poor maintenance by prior owner
- Rebuilt rear end <-Caused by poor maintenance by prior owner
- New right-side tie rod (normal maint.)
- New right-front hub w/bearing (normal maint.)
Brian
